Questions on CAI/Header/Exhaust Before Pulling Trigger
After I continued to read on this and other forums, I've developed some questions and concerns about the thermostat, and what the important aspects of tuning are, how important a dyno is - and I felt like I just couldn't understand it enough this summer, and figured I would postpone until next year. Now my sister has gone and suggested "wouldn't it be nice" if I came for a visit. . .
1) Has anybody had Chuck do this install and tune?
2) I thought I read somewhere that Chuck does have a dyno, and incorporates that as part of his tuning. Has anybody had dyno tuning at CoW?
3) Will this particular header/exhaust combination be anti-social, obnoxious? **** off my neighbors? How loud is it going to be?
4) Will the car start throwing codes after this kind of work?
5) Can I trust CoW to install what appears to be a crappy Vararam so that no unfiltered air leaks past into my engine?
6) Is there any down side to this modification? Any unintended consequences?
7) What happens to your gas mileage after this modification?
8) I've read that a wideband oxygen analyzer is essential, and I've also read that Chuck uses one. If he doesn't have a dyno, is the rest of his tuning, with the wideband, adequate?
9) Is there anything about this modification that's bad for the car?
10) Does the fact that I do most of my driving with the top down, and that I have a manual so I can change gears to change cruising rpm, allow me to avoid the potential Borla drone?
11) Is there any downside to the Vararam (let's leave out the discussions of sucking water into the engine)? Does anything have to be cut or modified on the car? You don't lose the foglights, do you?
I do plan on conversing more with Chuck, and of course he may get involved in this thread. I wonder about long distance tune changes, whether it be further refinement of the tune, or restoring the entire tune if a dealer wipes it out, etc. But I also wanted very much to get the experience and opinions of the forum. I think this is plenty to start with; thanks very much for your thoughts.
Joe
My first mod i did to my vette was vararam, exhaust, tune, MAF, ect and i must say was great for a little pick me up. Yeah it going to be louder but that comes along with mods. No codes thrown from those mods and gas milage went up. Starting out those are the most common mods guys do to there vette. Those are perfect mods with tune to give that extra boost.
Hope this helps
Good luck
The exhaust you named is great.. Top of the line.
Alot of guys on here will have mix feelings on vararam but tons still have it on there vette..
Chuck didnt tune my car as i have only read good things about his tune.
My opinion the items you named are great. But just like your worried just make sure whoever does the install is creditable. That is a major factor.. these other guys will chime in soon
6) Downsides: Headers increase engine bay temperatures, especially uncoated. As long as you have all wires (plugs, O2s, etc.) routed properly (which I'm sure Chuck would do), this is likely not a huge issue, but something to be aware of. Can also increase cabin temperatures. Might be a good time to install a tunnel brace while the exhaust is off the car. These increase the rigidity of the frame, and the thicker material also helps insulate the heat (can be bought with additional insulation material, as well) from making its way up into the cabin.
7) With just breathing mods, gas mileage should be either unaffected or improved. Very possible the extra power and sound will cause you to get on it more often, decreasing mileage, though!
9) As I said in 6, it could be argued the extra under hood heat is not great, could cause the plastics to become more brittle, etc. I personally didn't let this stop me, but since you're asking for downsides, that's really all I could think of
.10) I don't have direct experience with borla drone (I have LG Streets with Z06 Tis and don't really get drone), but wanted to mention the 6 speed should give you more freedom, but also if you switch from 6th to 5th for cruising, mileage will likely take a hit, since the secret of the 'Vette's stellar mileage is the gearing allowing the engine to make use of its low RPM torque and idle along at cruise. Depending on the speed may be negligible, I've never tried to track it.
I don't have any direct experience with CoW, but everything I've heard on the forum has been positive.
I think your idea of holding off on the cat back exhaust portion might be reasonable, to see how the sound changes with headers alone. Generally cat back changes are for sound rather than power/flow, so you should be fine without a re-tune, but maybe not 100% optimal. Chuck may offer some sort of a re-tune through mail option in the event you add/change mods, as well, so it might be worth talking to him about.
Good luck and let us know what you end up with!
Just kidding
Good luck
Gotta go to a meeting; back later . . .
Go to radio shack and buy a sound meter. if your under 89 dbs you should be good
I did all those mods a couple years ago, all at one time and couldn't be happier. Well, maybe the drone from the Magnaflow exhaust coulda been better, but like you said, with a manual, I just adjust the gear.
Best thing you could do for exhaust is attend a couple corvette shows or visit a club, and see if you can hear the various tones. I kinda wish my Magnaflows were a little louder, but they sound alot better than stock and good under accelaration. Other thing is, you can easily change out the catback and sell the used one here if you don't like it. Its really a personal preference of sound kinda thing.
Oh, and gas mileage - FORGET IT - once you pick up an additional 40hp or so it'll plummit cause ya can keep your foot outta it
One more initial "mod" suggestion, if you haven't already - "short throw shifter"
Good Luck and Enjoy
Does anyone do headers and not do a catback? Do we know what it sounds like?
m6 c5 - if you are catless, won't you be louder than I'll be with cats? I mean, the combo of straight pipes and catless would have to be as loud as we can get.
AU N EGL - now you're sending me mixed messages!
I don't need zero increase in volume; I'd like some. I'm just leery of crossing over some level that I can't describe, or correlate with a particular system.
And yes I would imagine that catless would be a tad louder but I dont think it would be by much. I am pretty sure that going catless has helped keep the temps down as I havent noticed much difference in before and after I installed the headers. I know a guy who has long tubes with stingers and it sounds good when you are behind it but it is loud and he said the drone is horrible.
