C5 Door -- Fix or Replace ??
Old Aug 1, 2012 | 02:36 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default C5 Door -- Fix or Replace ??
Guys - I've been Googling for a while with no positive results. I've been looking at a few C5s for sale and am getting close to a decision.
One I am looking at is under 40k miles and the paint is clean except for the Passenger Door.
Here it looks like either something impacted the door, or maybe it was opened over-far?
To describe it, view the attached pic. It is maybe a 1" vertical stress/rip mark in the body panel which is located about mid way between the side mirror housing and the front of the door panel itself.
I'm not sure if this is something that CAN be fixed, or if it is something I would even want to try if it won't come out good.
So I've been looking for replacement door body panels but haven't found them.
What are my options and proposed costs??
Old Aug 1, 2012 | 06:10 AM
SS2001SS's Avatar
SS2001SS
Why is the door off the car?
Old Aug 1, 2012 | 09:04 AM
jrose7004's Avatar
jrose7004
Without seeing it in person it's hard to tell.
Old Aug 1, 2012 | 09:07 AM
fendermender's Avatar
fendermender
From the description, definitely fix it.
Old Aug 1, 2012 | 09:16 AM
bop's Avatar
bop
Have the person that is trying to sell you the car to put the door back on the car it may be that it won't fit in the door hole.
Old Aug 1, 2012 | 10:08 AM
That is a good question. I would discuss with the seller and arrange to have the door looked at by a good body shop. Get a quote for repair or replacement and go from there. Not that you have to get a brand new door skin - you could check with a used parts forum vendor and see what a different door would cost and then figure in the paint job.
Good luck.
Old Aug 1, 2012 | 10:13 AM
TraceZ's Avatar
TraceZ
why are BOTH doors off the car?! ... and just sitting on concrete without anything to protect the paint?
Old Aug 1, 2012 | 03:45 PM
Tusc's Avatar
Tusc
** The picture is just an example - NOT the actual car **
The pic I posted is just to give an idea of where the mark is.
It doesn't sound like a good verdict for the door! I will need to look into it now. I thought it would be an easy fix or part swap. I mean they sell everything ELSE vette related out there.
Old Aug 1, 2012 | 03:59 PM
racebum's Avatar
racebum
Originally Posted by 8VETTE7
Doors for the C5 are very difficult to find. There are NO new ones available and used ones are very hard to find. A buddy had some damage his right side door and while the Insurance company approved a used door over repairing the damaged on he was unable to find a used door.
Good luck in your search.
doors are all over ebay for around $200-400
Old Aug 1, 2012 | 04:22 PM
minitech's Avatar
minitech
Would be easier to judge seeing the actual damage. It doesn't seem like something that would require a new door as you describe it. Why not drive it to the nearest auto body repair place and get a quote. Doors are available used.
Old Aug 2, 2012 | 01:19 AM
Tusc's Avatar
Tusc
I'll have to take pictures if I look at it again. By the time I can get out to see it, any shop in the area would be long since closed.
Old Aug 5, 2012 | 04:12 PM
minitech's Avatar
minitech
No problem. Just tell the seller that you want him or her to take it to a place to have the body work looked at during the day. Tell them to tell the body shop you will be calling later that day as the buyer. If they want to sell it there should be no problem with that.
In the end it is all about the price. If it is going to be $1000 to fix the door then offer $1000 less than you would. Probably would really be $100-300 to fix it.
Old Aug 5, 2012 | 04:56 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Let me see if I got this right, You post a picture of a door that needs repair and want to know if it should be replaced or fixed, Then to find out that isn't even the door that needs repair, To answer your question I think you should post the part that needs fixing. Then we know what you are up against.
Mr.Bill
To C5 Door -- Fix or Replace ??
