How many o2 Sensors on a 99? Which to replace?
Old 09-24-2012, 08:11 PM
ncsurveyor2007
ncsurveyor2007's Avatar
Default How many o2 Sensors on a 99? Which to replace?
I'm getting codes 1133 and 1153 which are o2 sensors. How many are there and how do I know which ones to replace?
Old 09-24-2012, 10:45 PM
m6 c5
m6 c5's Avatar
There are four total o2 sensors on the car, the two you are getting codes for are the front two.
Old 09-24-2012, 10:46 PM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
These are your two FRONT O2 sensors - Part Number - AcDelco AFS 75 - GM# 19178930
I was fouling out the Passenger side "ONLY" on mine and the Original AC Delco AFS 75 (GM 19178930) were still in there with 100,000+ miles on the O2 Sensors themselves -
Realize that you can even have one go bad without receiving a O2 sensor code!!! (I and others have had this happen)
Plus they have 735 RWHP Supercharged miles with Methanol Injection on them too!
I just put in the 2 new Front AC Delco AFS 75(GM 19178930) these are a New and Improved design as well, instead of slices in the sensor tip they have holes around it instead) -
Pictures:
New Style O2 Sensors AcDelco -
Old Sensors (AcDelco AFS 75) Passenger Side on RIGHT in Picture (100,000+ Miles on the Original O2 Sensors)
Thanks,Matt
Old 09-24-2012, 11:08 PM
ncsurveyor2007
Thanks guys. My 99 has LG long tube headers which were installed before i bought the car. I'm assuming the o2 sensors are still the same though? I'm ignorant when it comes to this stuff, sorry.
Old 09-24-2012, 11:15 PM
madmatt9471
No problem -
How many miles on the Vette (O2 sensors)?
Make sure you also check all the wiring to make sure the wires are not melted anywhere - they are easy to see when you are under there.
Thanks,Matt
Old 09-24-2012, 11:19 PM
ncsurveyor2007
110,000 miles. Not sure if they've ever been changed but I'd imagine they have since I've got headers and cam
Old 09-24-2012, 11:20 PM
ncsurveyor2007
Are the sensors pretty easy to get to once I'm under the car?
Old 09-24-2012, 11:22 PM
madmatt9471
Yes! It is time to replace those - get some soon! They are toast
I got mine from Amazon for $32 each with free shipping ($64 for both, free super saving shipping)
Thanks,Matt
Old 09-24-2012, 11:23 PM
madmatt9471
Yes! Easy and straight forward -
Thanks,Matt
Old 09-24-2012, 11:25 PM
madmatt9471
Not! Usually people overlook these as I did -
My bet is that they were never replaced and they are the original ones from the factory and that is why you got the issues!
Thanks,Matt
Old 09-25-2012, 11:02 PM
m6 c5
m6 c5's Avatar
You probably are running rear O2 sensors with adapters to allow them to plug into the front O2 sensor harness so you will probably want to get two new rear O2 sensors. The reason they use rear O2 sensors is because they have stronger heaters in them which is needed because they are placed further back than stock.
Old 09-26-2012, 07:03 AM
madmatt9471
This is debatable - They have been tested and show no difference
Make sure you inspect them first before you get anything
Thanks,Matt
Old 09-26-2012, 06:38 PM
m6 c5
m6 c5's Avatar
Thanks,Matt
Ah well either way it seems to be a common practice to put the rear O2's in the front when installing headers.
To How many o2 Sensors on a 99? Which to replace?
Quick Reply: How many o2 Sensors on a 99? Which to replace?
