Thinking about buying '97, Input requested.
06/27/1997
42 miles
Title or registration issued
First owner reported
Registered as
personal vehicle
11/23/1998
11,111
Service Facility
Oil and filter changed
03/30/1999
12,276
Service Facility
Engine/powertrain computer/module checked
Engine/powertrain computer/module replaced
11/11/1999
14,487
Service Facility
Battery replaced
04/19/2000
15,476
Outside mirror replaced/repaired
06/07/2000
15,928
Transmission checked
State safety inspection completed
A/C and heating control assembly replaced
05/11/2001
17,502
ABS/TCS computer/module replaced
Fuel filter replaced
ABS computer/module replaced
09/04/2001
17,762
Right front door lock actuator replaced
04/01/2002
Texas
Motor Vehicle Dept.
Registration issued or renewed
Passed safety inspection
05/08/2002
18,349
Recommended maintenance performed
Inside door handle replaced
09/05/2002
19,084
01/16/2003
19,904
05/01/2003
09/09/2003
21,562
Battery replaced
03/01/2004
Texas
Motor Vehicle Dept.
5/01/2004
Texas
Motor Vehicle Dept.
01/15/2005
22,335
Tire condition and pressure checked
04/11/2005
Maintenance inspection completed
Serpentine belt replaced
05/01/2005
Texas
Motor Vehicle Dept
07/27/2005
A/C compressor replaced
Brakes checked
09/12/2005
Vehicle serviced
05/01/2006
Texas
Motor Vehicle Dept.
04/02/2007
Drive belts checked
05/01/2007
Texas
05/01/2008
Texas
05/26/2008
Battery replaced
Four wheel alignment performed
Drive belt(s) replaced
Two tires mounted and balanced
05/01/2009
05/01/2010
Texas
03/01/2011
26,107
Battery replaced
05/01/2011
Texas
Motor Vehicle Dept.
07/19/2011
26,256
Battery replaced
11/02/2011
26,406
Vehicle serviced
...Then it goes to the current owner, with just registration reported...
No accidents reported.
Thoughts????
Thanks again...
06/27/1997
42 miles
Registered as
personal vehicle
11/23/1998
11,111
Service Facility
03/30/1999
12,276
Service Facility
11/11/1999
14,487
Service Facility
Battery replaced
04/19/2000
15,476
06/07/2000
15,928
05/11/2001
17,502
09/04/2001
17,762
04/01/2002
Texas
Motor Vehicle Dept.
05/08/2002
18,349
09/05/2002
19,084
01/16/2003
19,904
05/01/2003
09/09/2003
21,562
Battery replaced
03/01/2004
Texas
Motor Vehicle Dept.
5/01/2004
Texas
Motor Vehicle Dept.
01/15/2005
22,335
04/11/2005
05/01/2005
Texas
Motor Vehicle Dept
07/27/2005
Brakes checked
09/12/2005
Vehicle serviced
05/01/2006
Texas
Motor Vehicle Dept.
04/02/2007
Drive belts checked
05/01/2007
Texas
05/01/2008
Texas
05/26/2008
Battery replaced
05/01/2009
05/01/2010
Texas
03/01/2011
26,107
Battery replaced
05/01/2011
Texas
Motor Vehicle Dept.
07/19/2011
26,256
Battery replaced
11/02/2011
26,406
Vehicle serviced
Thoughts????
Thanks again...
He also mentioned he had the car professionally checked by some sort of lemon-check service before he purchased it, and he still has the paperwork from that (everything checked out).
My biggest concern is the electrical issues. I can see someone being a little lazy and not using a battery tender and also not driving it much leading to the battery issue. Don't forget, last year was the hottest year on record here in Texas, so I guess that could have also been a factor.
I want to buy the car, but I dont want to make excuses for the issues and end up with an expensive headache.
I see that the modules have been replaced, both ABS and the powertrain module (both more than once)... but I am so inexperienced with these cars I'm not sure of the significance of that issue. Is this the dreaded EBCM that is discussed? Or is it simply an eletrical box that can be replaced fairly easily?
I emailed Dennis for the report, thanks for the tip.
As I was reading the post, I was thinking "PULL THE DTCs,, PULL THE DTCs!!" You should also inspect under the car for leaks and hidden damage.
It should drive straight, shouldn't pull left or right and by all means,, TEST the EBTCM..
From approx 50mph, stomp the brakes and see if the antilock works properly and you don't get any failure messages. Should stop straight and fast.Low mile cars that sit a lot can have as many issues as C5 that have been driven regularly.
Things that I see as negatives:
PCM replaced SEVERAL times. Look for battery acid damage repairs. Check the frame and components under the battery for acid damage.
It has REAL TIME DAMPENING Suspension. IMHO it a waste of time and money. Not the best suspension for performance/spirited driving.
Two EBTCM replacements??? At least you have a new unit that working... Check the DTCs while the engine is running to see if you have any issues in that module.
What tires do you have? If they are the OEM original run flats, they MUST BE CHANGED!!! They will be hard and unreliable. Sounds like only two were replaced
Check for any evidence of battery acid damage under the battery. It was a very common issue on the early DELCO Side terminal batteries..
The GOOD:
Interior and exterior should be MINT!
What are your plans for the car. If its just a driver, you will be fine out of the box.
I had an early 98 and it was a daily driver here in New England and the winters were rough on the factory grounds. You should be fine for a southern car.
Bill
I drive a GTP daily, so the 'Vette would not be a daily driver. However, my GTP's tranny is weak, so I would need the vette when the inevitable happens... but for the most part, the vette would be in the garage (with the exception of weekends, the occasional drive to work, car shows, etc.). Although, with it being my first one, I'm sure it will most likely get driven a little more than expected.
I'm sure there are plenty of other C5's out there, but this is one of the best deals that I have found. Im 26 years old, and this is my first 'large' purchase out of college, and that's why I'm putting so much into the decision.
I did account for tires in the price of the car, the current owner did say that they will need to be replaced. As far as plans? Maybe wheels, tires, exhaust, intake, some tame visual enhancements.... nothing crazy. I was planning on replacing all fluids in the near future.
Bill Curlee has raised some light on some of the items listed in the links in the 2nd and 9th posts. Go back and read them again. Make yourself a list to take with you when you go to look at the car.
Not trying to prevent you from buying what could be a great car but you have already stated you want to avoid buying a nightmare. Check the car out carefully against a list you take with you and be as critical of items you find as you need to and you should be able to make the best decision.
Also don't fall in love with the car as soon as you see it. Go through your list with care. If this one doesn't measure up, don't worry as there are still a lot of C5's out there that will.
Good Luck!
Bill
Thankfully it checked out. Just kept me from talking him down on price any more.
However, I believe that if it has any current EBCM codes, it's probably going to be a no-go.
But you do have it all set-up perfect though! You have the perfect father sports car for the kids and then your weekend car also!
No kids here, though. The vette could probably help with that.
