added ccfl halo rings
They are 80mm halo rings that I got on eBay for 25$ or so. They are a bit bigger than OEM fogs so I wrapped 3 layers of 2 sided take around the fog lights and stuck them on. It holds pretty well. Each side is then grounded using one of those bolts in the frame right there where the fog lights are and I ran a wire for power up to the fuse block and tapped into the ac fuse so they are always on. If I decide to keep them, I'll get rid of my corner light led strips (i think it's too much to have both) and power them from the parking lights.
