Shakedown run with codes / minor issues to fix
Finally put a few hundred miles on the car since buying it. It runs good but I have a list of issues to correct.
I knew something was up with what I belived to be the yaw rate sensor needing replaced and the wheels not having TPS installed. The traction light has been on so today I pulled the codes:
Codes
• C1277 Requested Torque Signal CKT Malfunction
• C1286 Steering Sensor Bias Malfunction
• C1287 Steering Sensor Rate Malfunction
My tires are 235/35/18 front and 275/30/19 rear. Would they cause these codes?
C1288 Didn't locate this one
• B0432 Rear Defogger Relay Circuit
• U1040 Loss of Communications with TCS
These are fron not having TPS sensors
• C2100 Left Front TPM Sensor Malfunction
• C2105 Right Front TPM Sensor Malfunction
• C2110 Right Rear TPM Sensor Malfunction
• C2115 Left Rear TPM Sensor Malfunction
• U1000 Loss of Communication Undetermined
• U1064 Loss of Communication with BCM
I also need to fix the headlights. Previous owner installed Xenon HIDs. The only want to have them go down in to turn the brights on, then off. Each time I start the car, they open a inch each time. I can turn on and off and they will stay closed.
When turning the lights off, I have a gear grinding. I read here that they strip easily and a vendor offers brass gears. Sound like the correct fix?
I have to remove the windshield cowl to find the washer lines. They aren't connected and must of fallen below the cowl when PO installed a carbon fiber cowl.
These are the issues I've noticed. Any suggestions for a fix are appreciated. Otherwise the car is solid.
Codes
Would that also throw the service traction control warning?
Received 19,286 Likes
'20-'21-'22-'23-'24
Good luck getting all the problems ironed out.
1 Post
Here are instructions on how to replace the steering position sensor:
http://forums.corvetteforum.com/c5-t...on-sensor.html
Lots of members have added tips and tricks since I posted how I did it, so read through beyond my original posts. If you have a telescoping column (which I do not) it's supposed to be a lot harder as that column is larger and more difficult to get out. Otherwise, it's fairly straight forward.
Appreciate the link.
Today I did se additional trouble shooting. While parked and also driving, I cleared the TCM codes. The TCS light stayed off until I turned the steering wheel. Same results parked or moving. I feel confident that the SPS needs to be replaced.
