My engine has arrived - RHS 450cid & AllPro Heads
Old 12-21-2012, 08:55 AM
  #41
BillY2KFRC
BillY2KFRC's Avatar
Very impressive build, that is going to be a blast once it's all together! Nothing like a quality spare-no-expense N/A build, especially seeing it put into a C5Z!
I think you will especially like that TR6060. I recently went that direction when my built MN12 broke a main shaft and I couldn't be happier. Shifts like butter now, with my RSD short shifter, it feels much nicer than the shifter in my BRZ or my old S2000. Can shift with 1 finger if you want to.
I never realized the C5 B&B Fusion was 3", is that something new they make or was it a custom request? Or am I just dumb and it was always 3"? Either way, very curious to hear your opinions of it.
Old 12-21-2012, 09:00 AM
  #42
7LitreC5
Support Corvetteforum!
7LitreC5's Avatar
My setup is the same except that I have a LS7 block. I get about 1500 miles/quart if I am nice to it. Golen is going to bore it +.005 to clean up the bore and use new coated pistons.
Originally Posted by WKMCD
Regardless of what some people will tell you. It is very possible to have a stroker not burn any oil...mine doesn't. It's Darton Sleeves LS2 block with a 4.125 bore and a 4 inch crank.
Old 12-21-2012, 09:06 AM
  #43
BillY2KFRC
BillY2KFRC's Avatar
That's great to hear. Just about everyone I've ever talked to with a stroker motor has burned at least some oil. That was the biggest reason behind using a new stock internals LS7 crate motor for my 427ci build, not having to worry about that.
Old 12-21-2012, 09:17 AM
  #44
WKMCD
WKMCD's Avatar
I change the oil at 3k miles and it's still not needing any. Shawn Miller built my engine and used nitrited rings which should wear very little over a long time up against the super hard Darton liners.
What I save in oil I more than make up for in gas...
Old 12-21-2012, 09:39 AM
  #45
4 KRUSIN
4 KRUSIN's Avatar
Me likey!
Will it fit under the stock hood?
Old 12-21-2012, 11:29 AM
  #46
thecapo
thecapo's Avatar
Your right, I have one season on the TR6060 with my old 427cid setup and you can pretty much shift with one finger at any RPM - it is a great upgrade from the T56. I'm using a MGW shifter which I really like.
The 3" C5 Fusion is a custom order from B&B. The trick to get all the potential power to the ground on a big cube N/A build requires the EGT's to remain at reasonable level. Full flow 3" is really the only way to get the exhaust gas out of the combustion chamber quickly, resulting in lower temps.
As far as sound goes I am not to sure what to expect. I know in 'loud mode' it is going to be very loud. But in 'quiet mode' my hope is that it will be Police friendly. I will be posting idle and chassis dyno clips in both modes.
Old 12-21-2012, 11:37 AM
  #47
thecapo
thecapo's Avatar
You may want to consider 'lateral gas ports' as an option on your pistons. My understanding is that it will help to push the ring against the cylinder bore thereby reducing the risk of oil burning. They also claim it is good for 7 to 10hp - which is really good value when looking at $/hp.
Old 12-21-2012, 11:41 AM
  #48
WKMCD
WKMCD's Avatar
I've run a couple 2.5 inch catbacks one the 403 build with DMH cutouts also. The difference with the cutouts open on the dyno was 12-15rwhp IIRC. It would probably be a little more with the 427. I now run LG's Big 3 catback and the difference with the cutouts open is now only 1 or 2 RWHP. They aren't too loud and sound good. Now I'm 3 inches from the AR 17/8 LT collector to the tips.
Old 12-21-2012, 11:43 AM
  #49
WKMCD
WKMCD's Avatar
Shawn may have used them...not sure on that though. I'll have to go back and look at my notes. It's a pretty well optimized build.
Old 12-21-2012, 11:48 AM
  #50
thecapo
thecapo's Avatar
That is awesome!!!
I was not really sure what to expect in added HP. I will be 3 inches from my Kooks 17/8 collector to tip as well.
Old 12-21-2012, 11:50 AM
  #51
thecapo
thecapo's Avatar
Originally Posted by 4 KRUSIN
Me likey!
Yes, it does.
Old 12-29-2012, 12:42 AM
  #52
thecapo
thecapo's Avatar
Originally Posted by robert miller
To the OP here very nice build for sure love the RHS block. I cant wait until I get the RHS little 427 into the car and see what it does in the rollers.. Also that can on those numbers that is going to be one hel1 of a cam for sure.Robert
I think the cam on the 107lsa will be a bit of a beast in rush hour traffic.
Old 12-29-2012, 01:15 AM
  #53
itzza427
itzza427's Avatar
smiliedrool: All I can say is WOW,,,and maybe add I'm a little jealous too!!
Old 12-29-2012, 08:11 AM
  #54
MGP1
MGP1's Avatar
2020 C6 of the Year Finalist - Modified
Old 12-29-2012, 09:05 AM
  #55
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I would love to hear a sound clip of the motor!
Wondering how aggressive it sounds!
Thanks,Matt
Old 12-30-2012, 02:37 PM
  #56
thecapo
thecapo's Avatar
Thanks,Matt
Posting chassis dyno and idle video clips later this week.
Old 12-31-2012, 12:07 AM
  #57
madmatt9471
AWWWWSOME!
Really looking forward to it!
Thanks,Matt
To My engine has arrived - RHS 450cid & AllPro Heads
Old 12-31-2012, 09:23 AM
  #58
02HREBlue
02HREBlue's Avatar
Those poor little stock tires--------OUCH
Old 12-31-2012, 10:12 AM
  #59
DevilDog II
DevilDog II's Avatar
Oldtimer
Holy shnikey! I think I'm suffering from engine envy.
Old 01-01-2013, 01:45 AM
  #60
thecapo
thecapo's Avatar
I think I am going to order some Nitto - NT01's.
Quick Reply: My engine has arrived - RHS 450cid & AllPro Heads
