Traction/wheel spin
Old Jan 16, 2013 | 11:18 AM
f6john's Avatar
f6john
Default Traction/wheel spin
All stock 99 ls1 6speed. Z06 wheels with 295-35 18's. From a 5mph roll in first gear, should there be enough power to break the rear end loose? Tires have a 400 tread wear rating so not a soft compound.
Old Jan 16, 2013 | 11:39 AM
Quickshift_C5's Avatar
Quickshift_C5
Shouldn't have a problem breaking them loose at the bottom of 1st with a tire that hard.
Old Jan 16, 2013 | 11:44 AM
calvins's Avatar
calvins
Oldtimer
I'd sure think you should be able to burn 'em off if you wanted to. Just remember - replacing them isn't real cost effective... ;-)
Old Jan 16, 2013 | 11:53 AM
thecapo's Avatar
thecapo
I thought that's why we buy these cars? I go through 1-2 sets of rears per season.
Burn 'em off!!! LOL
Old Jan 16, 2013 | 11:56 AM
Yes, you should be able to break the tires loose at that speed.
Old Jan 16, 2013 | 01:17 PM
3sACROWD's Avatar
3sACROWD
My stock 03 Z06 will break free in 2nd gear while going 45 MPH using Goodyear Supercar tires with a traction rating of 220. I don't think your car would have any problems breaking free in 1st gear and possibly 2nd if you have a manual tranny.
After this season, I'll likely be looking for a different brand.
B4 anyone asks, the tires are two years old so age shouldn't have made my tires hard yet.
Old Jan 16, 2013 | 02:26 PM
f6john's Avatar
f6john
I also should have specified also, TC on, off or shouldn't matter? Reason I ask is that while my car has 312rwhp +/- I have never turned the tires over either by accident or on purpose. I have owned the car for 2 yrs and have driven the car from it's 49k mileage to almost 64k now without having to do anything other than oil changes, tires and clutch fluid service. So I'm wondering if I am in need of some other specific service related items to improve throttle response. It doesn't have any bad habits, starts good, idles good, pulls smooth, good gas mileage, I just thought it would be stronger down low than it seems to be.
Old Jan 16, 2013 | 02:30 PM
Phanni's Avatar
Phanni
TC will need to be shut off.
Old Jan 16, 2013 | 03:04 PM
CQRT's Avatar
CQRT
key point . . . .
Old Jan 16, 2013 | 03:07 PM
3sACROWD's Avatar
3sACROWD
Even with TC on, you can expect some spin before the computer takes over and cuts power. With TC off, wheel spin will continue longer until the tires grip. At least that is what I experience.
Old Jan 17, 2013 | 12:11 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Peace
Chip
__________________
..................Click for
Old Jan 17, 2013 | 08:41 PM
littlefranks's Avatar
littlefranks
i always turn tc off.wish i could disable it all together.
Old Jan 17, 2013 | 08:54 PM
knewblewkorvette's Avatar
knewblewkorvette
You can.
Product Description
Had enough with Traction Control? Sick of forgetting to put the car in Competition mode, or holding down that button for five seconds? Do you wish Chevrolet would have let you decide how the Traction Control or Active Handling systems are set when you start the car? Well, you don't have to do it Chevrolet's way any more! The TracActive Controller from LapTrax puts the power in your hands, where it belongs. Total control is what the TracActive Controller is all about. You can set the controller to disable Traction Control (and Active Handling, if equipped), place the car into Competition Mode, or simply remain passive and do nothing. You can even set whether the controller confirms it's operations with beeps or remains silent. Whatever option you choose, the standard messages will still appear on the Driver Information Center (DIC). To turn Traction Control and/or Active Handling back on, simply press the factory Traction Control/Active Handling switch on the center console at any time. The TracActive Controller is fully programmable using the factory Traction Control/Active Handling switch located in the center console, You can change operating modes any time without removing the controller from the car! Once you select your preferred operating mode, the TracActive Controller is completely automatic. As soon as you start the car, it goes to work. No action by the driver is required. The value of the TracActive Controller is even greater for owners of '99 and '00 vehicles which require the car to be stationary before switching into Competition Mode. By the time you're ready to get moving, the TracActive Controller has already done it's job! If you'd like even more convenience, purchase the TracActive Controller Deluxe. This upgraded model will automatically clear the "Competition Mode" or "TRAC/ACT HNDLG OFF" messages off the DIC after a short period of time. The TracActive Controller is not a simple timer and relay, cobbled together from basic parts. It is an advanced, programmable microprocessor controller device. It is manufactured in the United States with the latest surface mount technology and automated assembly processes. The TracActive Controller is completely solid state with no moving parts. Installation is simple, requiring only about fifteen minutes and a pair of pliers (the Deluxe version takes longer to connect the automatic DIC reset feature). The TracActive Controller is everything the C5 Corvette owner has been looking for. It's great for the street, strip or track. Automatically disables Traction Control and/or Active Handling! Automatically places the car into Competition Mode! Completely user programmable to your preferences! Works with all C5 Corvettes!
http://www.thelapd.com/profile.asp?I...&CategoryID=47
Old Jan 17, 2013 | 10:29 PM
m6 c5's Avatar
m6 c5
Id say you would have better luck around 10 or 15 as the engine would want to bog at that speed.
Old Jan 18, 2013 | 08:24 AM
Phanni's Avatar
Phanni
The junk yards of full of Corvettes that were driven by guys that were sure they were better judges of a Corvette's ability to handle traction and handling than the engineers programmed into those cars.
Old Jan 18, 2013 | 10:06 AM
Damillio's Avatar
Damillio
Mine doesn't break loose from a slow roll until it hits the power band
To Traction/wheel spin
