[Z06] TPiS ZL9 Cam
Old 05-17-2013, 10:51 PM
Hitman227
Hitman227's Avatar
Default TPiS ZL9 Cam
Why isn't anyone running this cam??? You might think it would be the best cam of many worlds, specifications 209/223/110, -4* overlap which is the same as a Comp 224/224/114 (Read: Emissions Legal).
On their website TPiS claims no loss of drivability with revs through 6800.
What's the deal?
Old 05-17-2013, 11:33 PM
ctusser
ctusser's Avatar
It might rev to 6800, but would be past it's peak hp at that point. It wouldn't be a bad street cam, but would be considered small. Most are going medium to large with cam swaps.
Since you are looking at odd ball cams, one I installed is 215/231 .631 .644 118 which has -12 degrees overlap, and behaves more stock than the stock cam.
Old 05-18-2013, 12:21 AM
Hitman227
Hitman227's Avatar
I realize something along the lines of an XER 232 would be bigger though not emissions legal. The advantage here is ability to generate the torque down low yet not run out of breath over 6000. No one runs Grand Am specifications on track or street using this cam?
Old 05-18-2013, 12:40 AM
ctusser
ctusser's Avatar
Since you're in NC I wouldn't think you'd have to worry about emissions since they just do an OBD scan, and if it's tuned to not throw codes you should pass with just about anything, as it is here in WA. California would be a different story, however.
Old 05-18-2013, 01:48 AM
Hitman227
Hitman227's Avatar
I'm not worried about sniffer at all, I can smog my car in a county vi P.O. box when I'm back in Cali, not even relevant. I'm wondering why anyone is not running this cam in their setup the way it is, torque down low with ability to rev.
Old 05-18-2013, 01:54 AM
Hitman227
Hitman227's Avatar
You may want to run numbers for powerband for the equation and most likely should, even then this cam has greater capabilities than lots yet at the same time no loss of drivability.
Old 05-18-2013, 02:55 PM
Hitman227
Hitman227's Avatar
Not to mention the overlap allows for greater breathing on the engine, which in turn increases the torque generated from the motor.
Old 05-18-2013, 02:58 PM
Hitman227
Hitman227's Avatar
Typical cams have less in regards to overlap, that's why you'll see greater torque under the curve, where it counts.
Old 05-18-2013, 03:01 PM
Hitman227
Hitman227's Avatar
The ability to rev is advantageous for street, that's where overrev through the gears on the motor will outmatch competitors.
Old 05-18-2013, 04:04 PM
AU N EGL
AU N EGL's Avatar
The Grand Am or Cup cam is very different then the cam you mention
GM- Grand am cup 88958606 239/251 570/570 106
I run a 224/224 581/581 112+4
Old 05-18-2013, 04:15 PM
ctusser
ctusser's Avatar
You don't know what you're talking about. You're just taking marketing info and making nonesense generalizations.
Old 05-18-2013, 04:40 PM
deadcafe
deadcafe's Avatar
What is the lift on this cam?
Old 05-18-2013, 05:04 PM
ctusser
ctusser's Avatar
Originally Posted by deadcafe
what is the lift on this cam?
.568/.584
Old 05-18-2013, 05:08 PM
Hitman227
Hitman227's Avatar
You can grind the cam to any specifications, although TPiS specs are .568"/.584".
Old 05-19-2013, 05:09 AM
Hitman227
Hitman227's Avatar
With valve events lined up like this, it's not surprising this cam carries over 6500, however for this to work as the advantage, it needs to generate the torque in the midrange to be good.
Old 05-19-2013, 05:15 AM
Hitman227
Hitman227's Avatar
Not sure why more aren't running this. Most likely they do not know the reason for odd timings. In turn not sure what numbers match.
Old 05-19-2013, 06:33 AM
ThumperNC24
ThumperNC24's Avatar
are you trying to sell this cam or something?
Most people wouldn't run a cam like this because the gains over stock wouldn't be big enough to go through all the trouble and expense of a cam swap is my guess.
Edit: You know you can also edit your posts. You don't need to make 5 in a row.
To TPiS ZL9 Cam
Old 05-19-2013, 08:26 AM
AU N EGL
AU N EGL's Avatar
Its not a sexy cam. Most ppl what BIG NUMBERS, not a cam that works well with the stock heads.
But it is a good cam.
Old 05-19-2013, 02:51 PM
Hitman227
Hitman227's Avatar
Not necessarily selling this, it's more of hobby to be clear. I don't care much for off-the-shelf grinds as they don't take advantage of greater air combustion, that's the difference.
These are three recommended for Road Racing:
GMPP ASA cam - 226/236 0.525"/0.525" 110 LSA (medium, 11* overlap)
One of Comp Cams Recommendations - 224/228 .566"/.568" 112 +2 (mild, 2* overlap)
One of Crane Cams Recommendations - 222/224 .585"/.585" 110 +3 (mild, 3* overlap)
Now here's the problem, none of these have torque lower in the powerband, even with gears it'll be tough to generate horses lower in the rev range.
Old 05-19-2013, 04:48 PM
Hitman227
Hitman227's Avatar
I'll agree, for balance mostly. That's why it's mind boggling there aren't any results with this cam.
Quick Reply: [Z06] TPiS ZL9 Cam
