Too much oil after oil change
Old 07-30-2013, 10:14 AM
Masterofsod
Masterofsod's Avatar
Default Too much oil after oil change
It looks like I put a little too much oil in my 02 z06. It is about a centimeter past the full line (I can take a pic if that hels). The garage I was doing the oil change in was dark and I guess I didn't see it was full when I added more oil in.
My question is: 1. Is this bad for the car? I read that if your taking it to the track or autoX you want to put more oil in it.
2. If so is there an easy way to get some oil out without draining it from the oil pan? Thanks!
Masterofsod is offline
Old 07-30-2013, 10:20 AM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
You don't know how many quarts you put in your car? if its 7 or less, you are fine.
Evil-Twin is offline
Old 07-30-2013, 10:27 AM
PNW Vett
PNW Vett's Avatar
St. Jude Donor '13
I would recommend not driving (or even starting/letting it run) the car with too much oil in it. Pull the drain plug and get it back to the correct level. It will be a bit messy, but in my estimation worth it.
PNW Vett is offline
Old 07-30-2013, 10:43 AM
oldC5
Support Corvetteforum!
oldC5's Avatar
Received 1,223 Likes on 734 Posts
Just drain and refill with new oil . You will sleep better .
oldC5 is offline
Old 07-30-2013, 10:56 AM
runner140*
runner140*'s Avatar
It was too dark to count quarts.
runner140* is offline
Old 07-30-2013, 11:00 AM
Masterofsod
I think it was 7, def. not more.
Old 07-30-2013, 11:01 AM
Masterofsod
Can I drain it and fill with the same oil? It has like 50miles on it since the oil change
Old 07-30-2013, 11:02 AM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You think?
When I change my oil and filter I always use 7 qts, Been doing this for 6 plus years and never had an issue.
How can someone change the oil and not be sure how much they put in or bought?
Mr.Bill is offline
Old 07-30-2013, 11:05 AM
JetMechZ16
JetMechZ16's Avatar
If it is 7 Qts or less I would not worry about it.
JetMechZ16 is offline
Old 07-30-2013, 11:12 AM
Masterofsod
Does your dipstick show more then full?
Old 07-30-2013, 11:15 AM
oldC5
oldC5's Avatar
[QUOTE=Masterofsod;1584539432]Can I drain it and fill with the same oil? It has like 50miles on it since the oil change
You can but why not just put new oil , or just take Mr. Bill advice 7 qts is ok. I am pretty sure you didn't put more than seven . Most of us buy 7 and put 6.5 . If you put more than 7 you need to let some else do your oil change .
oldC5 is offline
Old 07-30-2013, 12:25 PM
JetMechZ16
JetMechZ16's Avatar
Yes my dipstick shows slightly over the full mark when I put in 7 quarts. But I have a question for you. Since you said your reading is 1 centimeter (0.39 inches) over the full mark I'm assuming your in an area that uses the metric system. So did you put in 7 guarts or 7 liters? If it's 7 liters that may be too much.
Old 07-30-2013, 01:10 PM
6speedsteve
6speedsteve's Avatar
I always put 7quarts in mine and it is just a smidge past the hash mark, when I did my first change, 6.5 was just too low.
6speedsteve is offline
Old 07-30-2013, 01:12 PM
VinnyT
VinnyT's Avatar
How did you change oil in the dark??
VinnyT is offline
Old 07-30-2013, 01:17 PM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,836 Likes on 1,799 Posts
Checking the level in a Corvette requires the check be done after the motor has run and the oil warmed up, shortly after turning off the car. If you check it when it's cold it will not read correctly.
From the owner's manual:
"Do not check the engine oil level after the engine has
been sitting overnight. A higher than normal reading
might be obtained. Check oil level with the oil warm.
Turn off the engine and give the oil a few minutes to
drain back into the oil pan. If you don’t, the oil dipstick
might not show the actual level"
Corvette_Ed is offline
Old 07-30-2013, 01:55 PM
rkdc5z06
rkdc5z06's Avatar
I put about 7.2~7.5qt on my 02 z06
if you race, GM recommands you to put 1 extra quart on top of 6.5
It will help prevent oil starvation during long hard cornering.
rkdc5z06 is offline
Old 07-30-2013, 02:47 PM
Oldvetter
Oldvetter's Avatar
Yes, but they also recommend draining that extra quart out AFTER you are done racing.
I agree, 7 quarts won't hurt anything.
Oldvetter is offline
To Too much oil after oil change
Old 07-30-2013, 03:03 PM
envyz06
envyz06's Avatar
I dont understand how you dont know how many quarts you put in. Did you not count them?
envyz06 is offline
Old 07-30-2013, 03:07 PM
RetiredSFC 97
RetiredSFC 97's Avatar
St. Jude Donor '09-'10, '14
If you replaced the filter it's going to show over filled until you start the thing and let it run.
RetiredSFC 97 is offline
Old 07-30-2013, 07:27 PM
Evil-Twin
Evil-Twin's Avatar
You are suppose to fill the oil filter before spinning it up. I am amazed that people do not know this.
Quick Reply: Too much oil after oil change
