Leds bulbs in window switch c5
Old 09-09-2013, 06:38 PM
MARC C5
MARC C5's Avatar
Default Leds bulbs in window switch c5
I PURCHASED LED BULBS FOR MY WINDOW SWITCH, AND THE BULBS ARE A LITTLE BIGGER BUT THE INSTRUCTIONS SAY PUSH IN THE BULBS FIRST THEN TWIST TO LOCK. THE STOCK BULBS ARE SLIMMER . IS THEIR IN EASIER WAY WITH OUT BREAKING THE BULBS
Old 09-09-2013, 08:40 PM
VETJAZZ
Support Corvetteforum!
VETJAZZ's Avatar
The ones I got from JWMotoring fit perfectly, but I remember in a recent thread someone talking about using a dremel tool to trim theirs down a bit. Good luck.
Old 09-09-2013, 09:43 PM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
The 10mm bulbs are somewhat of a pain to install. We use 8mm base bulbs in our conversion kit which are MUCH easier to install (especially if you need to remove them because you got the polarity backwards) and fit all locations including the HUD and dimmer switch.
http://shop.radioflyerinnovations.co...ersion-051.htm
J. Kent (08-04-2018)
Old 09-10-2013, 01:39 AM
MARC C5
MARC C5's Avatar
To Leds bulbs in window switch c5
Quick Reply: Leds bulbs in window switch c5
