[Z06] Killer Bee is, well....killer.
Tuning on this is not a choice, it requires the purchase of a ls3/ls7 maf so its an requirement that a tune is needed to map out this new maf into the c5 ecu. All other cai using the stock maf like the blackwing don't require a tune but its highly recommended otherwise you will be running very rich during power enrichment mode which is 60%+ throttle situations and may get the occasional lean code if you don't tune. Even a stock filtered c5 z06 will benefit from a tune, so if you make changes even say a kn filter in place of the stock filter a tune would be advised. There are mail order options if you don't want to spend the money for a local dyno tune. If you want to monitor how much you car is trying to compensate from any cai or air filter mod get the torque andriod app and a blue tooth odb2 module and look at the short and long term fuel trims.
Depends how much its compensating, you will see when you go wot a look at the ltft as its added to the already enriched pe mode, I don't think you will be down anything noticeable from stock but there is more power that could be had if tuned correctly to maximize the blackwing modification. The supporting vendors of this forum imo offer a fair deal for a mail order tune for simple modifications like a cai, all you do is send in your ecu and they send it back tuned.
IAT sensor curve & cylinder charge temperature bias/filter should be tables should be modified for the LS3/7 card MAF.
Just commenting for future search & reference to this thread.
Cruising
Killer Bee
Thanks for the feedback,my tuner,(Force Fed) replied with basically the same input,I'm running Vararam
currently,so I'm interested in seeing gains.
Thank you,I'll be back,I'd like to see close to 500 steerable hp.
Heck it's only money,right?
The OP reported a 14 bhp increase over stock. Halltech claims 24. Who to believe, especially when it is pretty expensive for an intake. Many times more than I paid for my Halltech Stinger many years ago.
