Possessed C5....WTH
Old Jan 21, 2014 | 01:50 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Possessed C5....WTH
OK....here's the deal. 2002 C5 and the past few months when driving and for a few hours afterwards we get a loud popping/thumping sound coming from the car Nothing has changed, no new mods etc. When driving it sounds like it is coming from the tunnel below the shifter or from behind the dash. It sounds like something is smacking the bottom of the car. Come home and park in the garage and it will do this periodically for several hours. It is random and there is nothing loose under the car that could cause this. We had it on the lift last week and everyone in the shop heard it but no ideas where it is coming from.
Thoughts? suggestions? dumb answers?
see video added in post #41
Old Jan 21, 2014 | 02:10 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
First guess would be gas tank expansion...
Old Jan 21, 2014 | 02:18 PM
pewter99's Avatar
pewter99
seems odd based on where it seems to come from..
Old Jan 21, 2014 | 02:26 PM
LateBreak's Avatar
LateBreak
Exhaust system expanding/contracting with heat?
Old Jan 21, 2014 | 02:30 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Auto or stick?
Old Jan 21, 2014 | 02:38 PM
pewter99's Avatar
pewter99
no...thats the first thing everyone thinks...this is different besides if that was the case it would stop pretty quickly after it warmed up or for sure long before a few hours after being parked...I have had the car home now for 3 hours and it just made the noise again 5 minutes ago
pewter99's Avatar
pewter99
Auto or stick?
6 spd
Old Jan 21, 2014 | 02:42 PM
Corvette_Ed's Avatar
Corvette_Ed
The gremlin that normally lives in the electrical systems has moved to another location in the car but forgot to leave a forwarding address.
Any codes popping up?
Old Jan 21, 2014 | 02:43 PM
andrec10's Avatar
andrec10
Haunted?
Sorry, you knew it was coming....
Old Jan 21, 2014 | 02:44 PM
'Shifter's Avatar
'Shifter
NCM Member '09
What about something in the clutch slave, like the spring, releasing late or something?
LateBreak's Avatar
LateBreak
Try unhooking the battery next time you park it and see if it still happens? Could be some electrical component malfunctioning? If nothing else, you can rule that out if it still happens with the battery disconnected.
Old Jan 21, 2014 | 02:46 PM
LateBreak's Avatar
LateBreak
Originally Posted by andrec10
Haunted?
Old Jan 21, 2014 | 02:48 PM
pewter99's Avatar
pewter99
no codes..
Haunted?
yeah and I don't know any priests to do an exorcism
but repeatedly even after it is parked and off for a few hours?
hmmm
good idea...ya know it crossed my mind that it could be something electrical but with the car off I dunno....worth a shot
of course if thats it then we get to play the WTF is it game
Old Jan 21, 2014 | 02:50 PM
LateBreak's Avatar
LateBreak
Yeah, but at least then you'll have a hint
Old Jan 21, 2014 | 02:54 PM
pewter99's Avatar
pewter99
true...fortunately the C5 doesn't have many electrical components
the noise seems to have stopped....for now.......... but I will give that a try next time we bring it in the garage
Old Jan 21, 2014 | 02:56 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Based on your description, I suspect a vacuum is being pulled somewhere where it should not be and my first guess would be the gas tank. Next time you park it after driving it awhile, take the gas cap off and see what happens. Next guess would be cooling system, but this is far less likely given the sounds you are hearing.
If nothing there, I would suspect the noise is coming from something contracting as it cools (exhaust, etc.) and it is out of position vs. where it should be and does not have the freedom of movement it should have. This is obviously a hunting mission at this point. Don't overlook a broken motor mount as a possible cause.
Good luck - let us know what you find!
Old Jan 21, 2014 | 03:03 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Sport seats? Seat motor trying to move?
To Possessed C5....WTH
Old Jan 21, 2014 | 03:12 PM
jd_black_00's Avatar
jd_black_00
2016 C5 of the Year Finalist
St. Jude Donor '12, '14
I had something similar happen with my sport seats. The carpet got wet and shorted the passenger's side electronics and the motor kept making adjustments long after the car was off until the battery died. I solved the problem by fitting racing seats haha. Good luck!
Old Jan 21, 2014 | 03:16 PM
KOZ's Avatar
KOZ
Torque tube bushing coming apart?
Old Jan 21, 2014 | 03:37 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Seeing that appears to come from under the car, can you get it up on a lift or otherwise get under it and try to narrow down the area the sound is coming from? Even putting it up on jack stands and laying under the car for a few minutes may tell you more about where it eminates from.
