TPS SYSTEM Problem
Old Jan 30, 2014 | 08:09 PM
Johnljr's Avatar
Johnljr
Default TPS SYSTEM Problem
I got a code RFA 2105, and the info center said there was flat tire on right side so i changed out the tps, now there is a code for the left side front 2100, but still says right side flat, is that because i cant reset the sensor due to the front left being bad?
Old Jan 30, 2014 | 11:02 PM
El original's Avatar
El original
Have you had the car up to at least 25 mph to get the sensors activated?
Old Feb 1, 2014 | 04:30 PM
Johnljr's Avatar
Johnljr
i tryed retraining but the left front wont reset.
Old Feb 2, 2014 | 11:45 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Like 8VETTE7 suggested, try retraining them with a stronger magnet or have a shop help.
I was also wondering if they are the original sensors from 1998? If they are, it is lucky to have any still working as the batteries life has gone away. It could be that the RF failed first, but the LF was nearly the same and failed too.
To TPS SYSTEM Problem
