Engine compartment pressure wash
Old Feb 28, 2014 | 09:20 AM
bjones7131's Avatar
bjones7131
Default Engine compartment pressure wash
Any do's or don'ts when pressure washing engine compartment of 2001 c5
Old Feb 28, 2014 | 09:38 AM
CQRT's Avatar
CQRT
There have been several "engine cleaning" strings that you can find using the search feature that you will find helpful - - -but for me, the short answer of using a pressure washer is: don't.
Depending on the pressure force I think you can do more damage than good. Using it in the fender wells and undercarriage is probably fine- but for general engine cleaning, I'd suggest using a 50/50 mix of simple green on a warm engine. Put a plastic bag around the alternator and the fuse box.
I think you can use a hose with a spray attachment- and a stiff brush on areas where there's build up - - -you may need to hit it a couple of times. Some people use an air compressor to blow off excess water - - for the same reasons of avoiding a high pressure sprayer- I use towels and then let things dry naturally.
As a finishing touch- I use Tire Foam on all the plastics- again- avoid electronics- and wipe down with a damp cloth.
I'm sure others will chime in - - and maybe I'm overly conservative on my approach- but hope this helps.
Old Feb 28, 2014 | 09:57 AM
bjones7131's Avatar
bjones7131
Thanks, from what you guys say and other threads suggest; I will not be using any high pressure cleaning. This is why I love these forums, somebody somewhere has already been there and done that.
Old Feb 28, 2014 | 10:12 AM
UM Rebel's Avatar
UM Rebel
My opinion :
A little dirty and running well is good.
Spotlessly clean and not running is bad.
Old Feb 28, 2014 | 10:22 AM
jdvann's Avatar
jdvann
I learned the hard way...not with my C5, but with my trailblazer. I bought it used and took it to a detailer who as his standard, power washes under the hood. It was running perfectly when I dropped it off but when I picked it up it had what appeared to be a miss or vibration. After 2 hours of dealer diagnosis, I already had one shop give up, it was found to be the fan clutch...which on the trailblazer is electrical and mechanical. It appears some how the power wash damaged it. $550 later and I had a new fanclutch and a smoothe engine. No more power washes for me....
Old Feb 28, 2014 | 12:23 PM
JR-01's Avatar
JR-01
Do not pressure wash any newer car. You are asking for trouble. It is amazing what you can do with a bottle of de-greaser rags and brushes and then use a good protectant on rubber and plastic. My egine compartment was pretty dirty when I bought it. An hour cleaning and I got to this point. Plan on doing more when spring comes.
Old Feb 28, 2014 | 01:10 PM
chipscvettec5's Avatar
chipscvettec5
Never....my '01 hasn't seen water in 3 years.
Old Feb 28, 2014 | 01:12 PM
85corvettec4's Avatar
85corvettec4
id drop bricks if i saw someone doing that to a car like this now my old 84' corolla.... who cares
Old Mar 1, 2014 | 12:21 AM
Originally Posted by 8VETTE7
I'm assuming the engine is still in the car.... Yes, DON'T DO IT!!!! Unless you want lots of problems with the electrical.
Electricak connectors were designed to repel water that gets under the hood from normal driving. They were not designed to take the forces developed by a pressure washer.
If you want to wash the engine bay, use a low pressure hose and gently apply the water to the engine.
Old Mar 1, 2014 | 09:33 AM
countylawdog's Avatar
countylawdog
I wrapped electrical connectors / altenator / etc with plastic wrap, then I spray the engine compartment w/ a mix of Simple Green or Dawn, I lightly brush some of the dirtier areas w/ a soft paintbrush, I spray/rinse with water using a clean weed sprayer, blow it dry w/ air compressor ... finish w/ some nice detailing.
Old Mar 1, 2014 | 10:04 AM
bjones7131's Avatar
bjones7131
Mine looks about like this but if you look under the covers you can see some dirt but I will not be putting water on anything. I am a neat freak
Old Mar 1, 2014 | 05:25 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Good advise here.
I would add that I sometimes use low pressure no spot rinse at a car wash on a really dusty engine from about three feet above the engine components before the above procedure. Getting the dust out of the way first heps protect shiny stuff from scratches and the low pressure from three up hasn't hurt anything in all these years. Never forget it is a Chevy,,,,they are tougher than most think they are!
When the compartment/engine is clean and dry, Adam's "In & Out" detail spray is awesome ****. You just spray all the plastic, hoses, wiring covers, shrouds, metal, etc. on the engine. Shines them up and overspray on paint just goes away on it's own.
Old Mar 2, 2014 | 05:00 AM
crazystevex's Avatar
crazystevex
I have low pressure washed the engine of everything I have ever owned at one time or another and never had a single problem. But never hit it with high pressure. So do at your own risk
Old Mar 2, 2014 | 09:46 AM
bj1k's Avatar
bj1k
I do it all of the time on different vehicles , but you have to use common sense and plastic wrap any critical electrical parts and be careful where you direct the water.
Old Mar 2, 2014 | 12:42 PM
PhysicsDude55's Avatar
PhysicsDude55
When I was in college and worked as a detailer at a high end car dealership we used to pressure wash engines ALL THE TIME. The mechanics would too when they finished working on an engine.
No plastic bags or anything, just spray some degreaser on the trouble spots and blast away till everything is clean.
Not that I recommend doing that, but its not like 1 pressure wash is going to ruin your car.
In any case, a rag and some simple degreaser cleans almost anything. Wipe on some armor all or similar product on the plastic surfaces and everything should stay pretty clean and good looking.
Old Mar 2, 2014 | 01:21 PM
JR-01's Avatar
JR-01
A friend of mine pressure washed his 95 Vette. He went to the mall after and it would not start. He spent hundreds of dollars on a tow, the dealership drying everything out and replacing a sensor. My wife bought a used Mercury Sable. The dealership had detailed it including pressure washing the engine bay. For the first three months we had big trouble with the electronics. Brought it back to the dealer at least a half dozen times, drying things out and replacing electronic components. After that we never had a problem. They lost money on that deal. I do not believe new cars were intended to be pressure washed. Old cars weren't a big deal. Pull the distributor cap and dry it out and you were good to go.
To Engine compartment pressure wash
