Targa Cars with Subs
Old 03-02-2014, 12:39 PM
TheTinMan
TheTinMan's Avatar
Default Targa Cars with Subs
So I was just curious if anybody had a Targa car and the molded sub boxes that go in the corners of the hatch area? If so do they interfere with putting the top in the back? Just planning what route i'm gonna go with my Z that i get next weekend. The targa conversion is almost a definite at this point and i like the corner boxes, but if they won't work i'll probably build a box. Let me know.
Old 03-02-2014, 02:16 PM
Uhhtaken
Uhhtaken's Avatar
Location: Jacksonville,nc and Williamsburg,va North Carolina and virginia
I don't have them molded into the corners but here's and idea for you.
It took me and a buddy about 40 hours to do and man can I say it is sweet and gets a lot of compliments.
Old 03-03-2014, 10:03 PM
TheTinMan
TheTinMan's Avatar
What i want to see is a car that has a sub or subs and still puts the targa in the back.
Old 03-03-2014, 10:22 PM
RoccoC5
RoccoC5's Avatar
I have one of the Vette Nuts sub boxes (http://www.vettenuts.net/index.php?l=product_detail&p=299) and it clears the targa no problem. Sounds great, too!
Old 03-03-2014, 10:29 PM
TheTinMan
TheTinMan's Avatar
Got any pics of the top stored with the sub in there?
Old 03-03-2014, 10:34 PM
lonerider2002
lonerider2002's Avatar
I installed a Rockford/Fosgate 150 watt mono amp and dropped a 10" JL Audio sub in the center compartment and the only other thing I added to the factory system was a pair of JL Audio two way speakers in the rear leaving the door speakers alone and it sounds great! This way I can still put the cover over the compartment when I need to & nobody ever knows its in there. The targa top still fits in the holders just fine. The good thing is easy removal if I sell the vette. At first I didn't think that the combo would have enough "oomph" to suit me but boy was I wrong. It hits as hard as a friend of mine's 500 watt 12" sub in his Trans Am--and cleaner too.
http://forums.corvetteforum.com/memb...22-143844.html
Old 03-04-2014, 01:25 AM
ZachHasAVette
ZachHasAVette's Avatar
well if you're getting a z then thats a completely different trunk/hatch space. i don't know if the targa top would fit in the trunk or not, as for the picture posted above, you don't really need to have the top in the back for the picture to see if it fits. as long as the subs don't interfere with those small black pieces on the floor for the top to sit in you should be fine, but with the stealth box and the corner mounts i don't know, i have some in the same place like Uhhtaken and the top fits fine
Old 03-04-2014, 06:28 AM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
I have had a corner sub box for almost 8 years now with s 2.75" mini-tub (top now stays flat in hatch). No problems storing the top before the mini-tub or to now. The biggest issue is cone placement and magnet clearance on a higher powered woofer.
Old 03-04-2014, 08:15 AM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,836 Likes on 1,799 Posts
This isn't the best picture but this is my setup using the center storage area. I can take a better picture later after the sun comes up if you'd like. My targa top clears the 12" sub and amp easily.
Old 03-04-2014, 09:33 AM
Marc@Vettenuts.net
Supporting Vendor
Marc@Vettenuts.net's Avatar
St. Jude Donor '11
I dont have a pic with the top installed but here is 2 in each corner of my personal car.
Old 03-04-2014, 10:25 AM
7LitreC5
Support Corvetteforum!
7LitreC5's Avatar
I have the Vettenuts corner sub and the top fits fine. My car is also mini tubbed and even with the mini tub the corner sub fits fine.
Old 03-04-2014, 10:40 PM
TheTinMan
TheTinMan's Avatar
Good to know. Wish someone with a Z and targa conversion could chime in here lol
Old 03-04-2014, 11:05 PM
PvtJoker21
PvtJoker21's Avatar
i had a custom box made for mine. I dont have pics but it was designed to go under the targa when its in the back. made it work with a 12" rockford
Old 03-05-2014, 09:18 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
Our sub boxes will clear the targa in your Z if you do the conversion.
Old 03-05-2014, 09:21 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We also have all the parts you will need to do the conversion. You can kill two birds with one stone here with VetteNuts.
Old 03-05-2014, 02:36 PM
matthewlfd
matthewlfd's Avatar
Here is what I have, hidden in the middle cubby:
Old 03-05-2014, 02:59 PM
Pirateslife4me
Pirateslife4me's Avatar
Looks great, hows it sound and where is your amp monuted?
To Targa Cars with Subs
Old 03-05-2014, 03:22 PM
matthewlfd
matthewlfd's Avatar
Sounds awesome. The middle of the cover is a metal speaker grill covered with fabric so air can still move.
I have all the speakers amped and I mounted the amp so it's hidden underneath the passengers seat. Gets plenty of airflow for cooling down there.
Old 03-06-2014, 08:58 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We also carry the center boxes for your C5 for $89.99.
Old 03-29-2014, 12:43 PM
Db1971
Db1971's Avatar
How much airspace did you end up with for the sub?
Quick Reply: Targa Cars with Subs
