Twilight Sentenal Mode
Old Apr 1, 2014 | 11:55 AM
ram01's Avatar
ram01
Default Twilight Sentenal Mode
I have 2001 conv.I drive it year round weather permitting.Sometimes it sits for 3 weeks.My question is,does Twilight Sentenal mode put any more strain on the battery?
Old Apr 1, 2014 | 01:20 PM
JR-01's Avatar
JR-01
I turned off the Twilight Sentinel on my '01 Vert. Saves wear and tear on the pop up headlights and I am smart enough to turn the lights on and off as I need them.
Old Apr 1, 2014 | 03:49 PM
Phanni's Avatar
Phanni
Twilight sentinel is wrong on so many levels in a Vette.
JMNSHO
I actually tried it once, and removed it after about two days.
Old Apr 1, 2014 | 04:27 PM
ram01's Avatar
ram01
Thanks I did not even think about gear wear on headlights.
Old Apr 1, 2014 | 04:34 PM
coia96vette's Avatar
coia96vette
The first thing I did when I bought my 04 was to turn that idiotic function off. I am more than capable of turning my headlights on and off.
Old Apr 1, 2014 | 04:44 PM
VETJAZZ's Avatar
VETJAZZ
Originally Posted by 8VETTE7
If you park the car in a garage regularly, the Twilight Centinal puts a strain, so to speak, on the plastic headlight gears by raising the headlights when you start it in the garage only to put them back down once you back out into the daylight. Similarly one needless cycle when you drive from daylight into the darker garage. JMHO
I've had mine off for years.
Old Apr 1, 2014 | 05:48 PM
JR-01's Avatar
JR-01
It really is a horrible option and waste of money.
Old Apr 1, 2014 | 05:58 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Besides the wear on the headlight motors, for those of us with HID headlights it is also more wear on the ballast and bulbs. It is a feature akin to the automatic headlights on most cars today, but as stated you can live without it as most remember when it is dark enough to require lights.
Old Apr 1, 2014 | 06:04 PM
C5Txfan's Avatar
C5Txfan
First thing I did on my previous '01 and current '04
Old Apr 1, 2014 | 07:28 PM
jdvann's Avatar
jdvann
I also turned off the memory function...seems like a lot of excess movement having the seat and steering wheel adjust automatically every time I got in it. I could feel it put pressure on the back of my seat when it went all the way back. I bet that adds to the rocking seat problem so many seem to suffer from.
Old Apr 1, 2014 | 09:30 PM
JR-01's Avatar
JR-01
How do you turn off the memory function?
Old Apr 1, 2014 | 09:46 PM
jdvann's Avatar
jdvann
It was an option I found in the DIC. It was called Seat easy entry...I set it to OFF.
Old Apr 1, 2014 | 10:39 PM
jdvann's Avatar
jdvann
That doesn't turn memory off. It simply stops the seat from moving at vehicle entry and exit. The memory function still tracks mirror positions, telescopic column, radio choices, seat position and climate control and adjusts those based on the FOB used to enter the car. If you always use the same FOB or only have one FOB they effectively are not causing any changes. But the memory function is still alive and operating should another FOB be used.
Agreed...it was the constant moving of the seat and steering column I wanted to stop. Just like twilight sentinel, anything that causes automatic movement every time you get in the car, can only help lead to premature wear.
Old Apr 2, 2014 | 12:07 AM
Doesn't really hurt the battery, but will put more wear and tear on the headlight motors and gears.
I used to keep my twilight sentinel on all the time but have now turned it off to keep the wear down.
Old Apr 2, 2014 | 07:03 AM
JR-01's Avatar
JR-01
So there is no way to deactivate the memory?
The guy that sold me the car was so into the Twilight Sentry, memory etc. I was just thinking how I was going to shut that crap off.
Old Apr 2, 2014 | 08:42 AM
alxltd1's Avatar
alxltd1
You can turn off the Twilight Sentry and the Easy Entry/Exit (which will as stated stop the seats from moving back when getting in or out) but not the memory. If you turn off the Easy Entry/Exit the seats and other positions, mirrors, telescoping steering column, will still go to the memory position associated with the FOB you are using when you start the engine.
Old Apr 2, 2014 | 08:55 AM
JR-01's Avatar
JR-01
OK. I will only use one FOB.
To Twilight Sentenal Mode
Old Apr 2, 2014 | 09:10 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Same here. Saves wear and tear on the headlight gears.
Old Apr 2, 2014 | 11:15 AM
65GGvert's Avatar
65GGvert
Set the memory the same for both fobs, then it won't matter which one you use.
Old Apr 2, 2014 | 11:45 AM
JR-01's Avatar
JR-01
Yep. I had the 2nd one set for my wife and since she is 4'11" it made a huge difference which FOB I grabbed.
It would be nice if you could just disable it, though.
