White LED solution from Radioflyer Innovations
Supporting Vendor
White DRL solution from Radioflyer Innovations
For those of you who have been wanting a white DRL while still retaining the Amber turn signal function, you know that because of the design of the corvette's turn signal circuit, both the DRL and turn signal are Amber and any change required significant re-wiring....
....until now
Radioflyer Innovations is proud to introduce the first Direct plug-and-play adapter harness that converts the DRL function to white using traditional switchback bulbs.
Video showing function with our Cree switchback LED Bulb. (C5 owners can use the Gen 5 switchback bulb with the factory bulb mount or the Cree LED bulb if the rear-mount modification is ordered)
How does it work? Our harness uses a solid-state time delay-off circuit to power the Amber portion of the switchback bulb that resets every time the power is shut off. The DRL power is run though the harness to the white portion of the switchback bulb. A set of diodes prevent backfeed to each circuit. The result:
Turn signal/Hazard: flashing amber/off/amber/off
DRL and Parking light: White
The harness for the C5 does NOT have a resistor. It's recommended to use the Hyperflash harness instead.
Harness is offered for the C5 in 2 versions:
A) Plug and play version, simply remove switchback bulb from the socket, connect install the harness and install the bulb in the new socket.
B) Splice in version with no connectors. Installation involves cutting harness to turn signal socket and splicing the harness in place. (slightly cleaner finished look and less expensive)
Harnesses are available for Pre-order here.
http://shop.radioflyerinnovations.co...arness-089.htm
Switchback bulbs available here:
http://www.shop.radioflyerinnovation...-Bulbs-055.htm
First harnesses will ship Late December.
....until now
Will these work with the euro tails?
I bought LEDs and a harness like this on ebay but returned them because they screwed up the signals with dash lights coming on when I pressed the brakes and other funhouse dysfunctions.
Supporting Vendor
I would recommend getting our hyperflash harness as well, this way if you decide to upgrade the bulbs in your euro tails to LED, you can just plug in the new bulbs.
There should be no issue with your lights. In my experience The "poltergeist" problem you had with the LED bulbs has to do with a weak ground in the engine bay. The LEDs simply showed the problem. It's a rare issue, but with the factory bulbs you're unlikely to ever notice the problem.
I also have a Big 3 kit.
It was the rear LEDs I tried that turned on the dash lights when I pressed the brakes.
So if I get your front and rear LEDs and your harness it will all work?
The other guy told me his harness and LEDs would not work with the eurotails after I contacted him.
Supporting Vendor
I cut these out and soldered all the grounds to washers.
We have used LEDs in both types of cars before without issue, but this may be a good place to look for the source of the problem.
Interesting. I have never heard of this issue with euro tail lights before. Is your car an export with euro from the factory or is it an aftermarkert modification to s North American spec car?
The other guy's harness clipped in between a connector under the dash but I see your setup is different.
I will try out your product as I don't think there's anything wrong with my car as far as grounds go or otherwise.
Supporting Vendor
Same deal for me. Euro tails cut wire and dash lights illuminate when hitting brakes. Anyone solve this?
Dave
Dave
Supporting Vendor
Do all your parking lights come on when hitting the brakes? If so this means you may be getting bleed over from the brake light circuit to your parking light circuit.
Supporting Vendor
If you would prefer, we can install the diode for you, but this will require you to send us your harnesses.
Remove the white DRL harnesses and see if the problem still occurs. If so, you can install a diode on the white DRL harness (on the connection for the "B" circuit to prevent back feed into the parking light circuit. The current version of our white DRL harnesses have these diodes already installed. Only a hand full of our harnesses were part of a revision that did not have this diode installed. I'm willing to bet that your dash light probably blink with the turn signals as well. A diode on each harness will solve your problem.
Dave
Supporting Vendor
A = high power (DRL/Turn signal)
B = Low power (Parking lights)
G = Ground
You want a diode on the B circuit which should be the middle wire. You can install this on the harness we provided if you don't want to mess with your factory wiring. Just make a note of the contacts and their position in the black connector to identify the correct wire. If you are in doubt, send me a photo and I can ID the correct wire.
Thanks. I would assume if the problem still occurs after unplugging the DRL's and the harness that the problem won't be resolved w/ the diode right? I also assume that if this does NOT occur with the DRL's plugged in that I'll need a diode on both harnesses correct?
Dave
Dave
Supporting Vendor
Dave
Dave
If you do end up needing a diode, you will need one on both sides.
