Accessing oil sender through wiper tray
Old 02-15-2018, 10:55 PM
  #101
chasboy
chasboy's Avatar
Oldtimer
I’m concerned about that line, which I believe is a fuel line. I don’t understand the mechanism. Does it cut the flow of fuel when removed?
Old 02-15-2018, 11:07 PM
  #102
dbgoodwin
dbgoodwin's Avatar
like I said, unless you're completely removing the manifold then there's no reason to unhook the line. It's flexible and you can easily get the manifold completely out of the way without needing that line disconnected.
If you do remove it, you'll get a little bit of fuel but not a lot. Similar to replacing a fuel filter.
chasboy (02-15-2018)
Old 03-13-2018, 10:08 PM
  #103
Ed Ramberger
Ed Ramberger's Avatar
Originally Posted by Choreo
It goes against my grain too, but cutting the hole and fabricating a removable "door" for my opening is what I decided on for me.
• First of all the "right way" makes no sense to remove so many bolts and connections just to perform this procedure - it opens up the possibility of creating other vacuum leaks, etc. just to perform what "should have been" a simple task.
• Since the OPS is a well documented "weak link" and prone to failing, it is very likely that the procedure may have to be repeated in the future.
• Coming in from the top directly make the procedure more reliable since you can easily reach, replace and torque everything as well as check for leaks.
Even doing the "relocation" procedure adds more potential leak locations.
The last time I replaced mine, two years later, mine developed a small leak (not reflected on the gauge). At first I thought it might be a main seal , but there was just a drop or two of oil on the floor every so often. I finally pulled the cowl, opened that door I made, and sure enough there was just a small amount of oil around the base of the OPS (even though it had been torqued to spec 2 years earlier). Quickly re-torqued, no problem since. If it fails again - 15 minutes to swap.
The "right way" would have been for GM to use a more reliable sensor in the first place AND put it in a location that could have been serviced without removing the top half of the engine instead of using a cheaply constructed sensor and then designing the whole car around it!
I REALLY did not want to cut my cowl, but it just made more logical sense in this case to me. If I really thought it might be a one-time thing, may have gone another route, but I am on my 3rd sensor.
Choreo, can you tell us how you really feel?
Old 03-14-2018, 07:18 AM
  #104
DirtRoad
DirtRoad's Avatar
I fastened the piece that was removed in place with Gorilla Tape. Years later, it is still doing the job. I feel absolutely no guilt for cutting the access door that should have been provided by Chevrolet when they designed the car.
ArmchairArchitect (03-15-2018)
Old 03-14-2018, 09:10 AM
  #105
jjc508520
jjc508520's Avatar
Funny to see that 3y later my thread still has life! For what its worth - the oil pressure sender is still working fine (as he curses himself - to come home to a pegged gauge!)
Old 03-14-2018, 09:31 AM
  #106
STALION
STALION's Avatar
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Get to it the proper way, and then add a relocation kit...problem solved. I was going to cut into it and my mechanic scolded me lol.
Old 03-14-2018, 09:50 AM
  #107
JR-01
JR-01's Avatar
Received 1,063 Likes on 805 Posts
You're afraid of your mechanic?
We have determined that some people would only fix it the dealer way and some would do it their way. Either way works.
Old 03-14-2018, 10:07 AM
  #108
STALION
STALION's Avatar
That was a little tongue and cheek. I did major upgrades last year and was in need of a new pressure unit and was going to cut into it and make an access panel. My mechanic who I do track with would have none of it and said he would do it the proper way...who am I to argue!? lol
Old 03-14-2018, 10:28 AM
  #109
JR-01
JR-01's Avatar
I had mine done the "proper" way, too, but I see no problem with doing it the other way, either. To each their own.
Old 03-14-2018, 10:49 AM
  #110
STALION
STALION's Avatar
I don't disagree, was just making light of the issue.
Old 03-14-2018, 04:44 PM
  #111
garllo
garllo's Avatar
When I had my first C5 (98 coupe) I was faced with replacing the oil pressure sending switch. I thought it over ,should I remove the intake?, should I use the other method and try to get around the intake with a universal on the socket as shown in the video?, or should I cut a opening and create an access doort? Here are my thoughts; If I removed the intake and replaced the oil pressure sending switch ,reassembled and had the switch defective or leaking I wouldn't be able to readily see it. Going by the video didn't appeal to me because it's difficult to start the new switch straight (remember ,aluminum block) and it's impossible to torque. I ended up cutting an opening which is what GM should have done in the first place and luckily I did because when I removed the old switch I discovered that it was replaced before and the threads in the block where cross threaded. Luckily I have access to CNC equipment. I fabricated a chasser and a guide to keep it straight (1ft long total) ,then ran a tap in the hole. worked out well . I think if I need to replace one in my 2004 ,I'll have my tech do it!
Old 03-14-2018, 07:28 PM
  #112
msandym
msandym's Avatar
Originally Posted by rrwirsi
I don't get it. The forum is full of mods that people do to their cars and most get raving reviews. Here is a person using his ingenuity to make the oil sender easier to remove for him and he gets trashed by some for doing it. If my sender unit ever needs replacing, I will consider doing what jjc did. The only change would be to design a “door” access for any future replacements.
Nobody trashed the guy . Some people respectfully said they wouldn’t do it !
Old 03-15-2018, 02:36 AM
  #113
jdmvette
Night Owl for life
Support Corvetteforum!
jdmvette's Avatar
Received 3,239 Likes on 1,663 Posts
Originally Posted by Jeff T.
Most of us don't use our cars as DD's,
Old 03-15-2018, 06:37 PM
  #114
jrprich
jrprich's Avatar
As to not relocating the OPS.........I had three brand new OPS fail in the original location in less than a year after replacing the original.
Once I relocated the OPS, no more failures after several years of almost daily use.
Old 03-16-2018, 03:19 PM
  #115
JR-01
JR-01's Avatar
Originally Posted by suchcoolness
I'd be will
Hi, Will.
Old 03-16-2018, 05:32 PM
  #116
novasscnc
novasscnc's Avatar
Cut a neater hole with a hole saw, then put a rubber grommet in the hole
Old 03-16-2018, 06:19 PM
  #117
001pewter
001pewter's Avatar
St.. Jude Donor '17-'18
I'd be will
Like talking to a old azz man, finish the sentence already
Old 03-16-2018, 06:22 PM
  #118
JR-01
JR-01's Avatar
More like talking to a millenial.
Quick Reply: Accessing oil sender through wiper tray
