Mgw ftw!!!
Old Apr 27, 2015 | 09:43 PM
Raith's Avatar
Raith
Originally Posted by Ludeaem
so do the newer MGW kits come with the new lower box?
Yes, it comes with the complete lower box assembly as well as the alignment tool for it. it was a very simple install. will take pics of the completed install as soon as i get back from my work trip.
Also, everything in the kit comes pre-lubricated...
https://www.mgwshifters.com/shifters/corvettes/88
Old Apr 28, 2015 | 03:04 AM
crazystevex's Avatar
crazystevex
When I bought mine I had to buy the new lower box seperate from the shifter. Unless they selling them as a kit now you'll have to buy it extra.
Old Apr 28, 2015 | 02:19 PM
DonsLS1's Avatar
DonsLS1
Ordered mine about a week and a half ago. I had to get one because everybody makes this shifter out to better than sex! The curiosity is killing me to get this thing and drive my car. If it makes as big of a difference as everyone says it does, it will be money well spent!
Old Apr 28, 2015 | 09:43 PM
Raith's Avatar
Raith
Very well spent money indeed... i swear, this is the best mod i've ever done to a car.
Old Apr 28, 2015 | 10:01 PM
jhopper408's Avatar
jhopper408
I've had all 3 top brands. And I still think the Hurst is the best.
Old Apr 29, 2015 | 12:46 AM
j5m's Avatar
j5m
Glad to see these positive reviews. I ordered an MGW shifter and their race **** a few weeks ago. Should be here on Friday.
Really dislike the stock shifter.
Old Apr 29, 2015 | 01:33 AM
Nyt_Muves's Avatar
Nyt_Muves
My 02 has the MGW. I love it but have a question. I now have trouble hitting 5th. It feels like there is a second location for third gear... I am getting used to it, but is there something else I need to check? Would this VENOM mod help?
Old Apr 29, 2015 | 07:49 AM
Koufax's Avatar
Koufax
Had my MGW installed last week. I am disappointed at how much harder I have to push / pull the shifter. I do find the shifting to be more precise, but it feels more like weight lifting than like shifting a car. (OK, I exaggerate). I also find that the MGW shifter ****, being made of hard material and having a bit of a sharp edge where it flattens out on top, cuts into my hand a bit when I make the shifts.
I suppose the anti-venom mod comes next.
Last edited by Koufax; Apr 29, 2015 at 08:08 AM. Reason: found instructions for anti-venom mod
Old Apr 29, 2015 | 08:45 AM
Raith's Avatar
Raith
Could be an alignment issue with the lower box on the shifter...
The Anti-Venom mod just adds a washer or two to the shifter detent plug on the transmission, basically reducing the notchy feeling that the t-56 is known for... one down side is this makes it easier for the transmission to slip out of gear, (i know some t-56 cars have an issue with staying in reverse or first if the shifter is not held there)
If you are interested in doing the Anti-Venom mod, Toque did an awesome graphical write-up of how its supposed to go. http://www.toquez06.com/avm.html
Old Apr 29, 2015 | 09:37 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Give it a few weeks to break in and the anti venom mod wouldn't hurt.
Old Apr 29, 2015 | 12:41 PM
Mickster144's Avatar
Mickster144
I have to agree ...and I still miss 3rd gear at times. I have had mine for over a year.
Old Apr 29, 2015 | 12:46 PM
vpshockwave's Avatar
vpshockwave
Had the same issue when I first installed mine. When I installed it I screwed the shift rod all the way down into the box as far as it would go and I put my **** on all the way down. I backed the shift rod out to the minimum number of threads recommended by MGW (maybe even a little less) and I moved my shift **** up a bit higher as well. The increased leverage made shifting 10x easier and I haven't had any issues since (haven't snapped the rod either, good considering I barely have the recommended threads in).
Food for thought! I'd advise tweaking it a little as I don't think the overall force necessary to shift will really change with the anti-venom mod.
Old Apr 29, 2015 | 01:08 PM
  #33
Mickster144
Thanks for the tip...I will give it a try. I don't think I want to mess with the anti-venom mod.
Old Apr 29, 2015 | 01:45 PM
  #34
Nyt_Muves's Avatar
Nyt_Muves
Thank you very much. so am I the only guy having trouble hitting 5th?
Old Apr 29, 2015 | 01:47 PM
  #35
Koufax's Avatar
Koufax
Fifth is not a problem for me, but sixth is a bit of a challenge.
Old Apr 29, 2015 | 01:50 PM
  #36
Koufax's Avatar
Koufax
Thanks for the suggestion, it sounds worth trying.
I had the shifter installed by the dealer because I didn't have the time or skill to do it myself. But if I understand this recommendation, it is a much easier job, one that I should be able to do in a few minutes. Does that sound right?
Old May 3, 2015 | 09:44 AM
  #37
Koufax's Avatar
Koufax
I tried it and it worked. Much happier now. I am going to go back to the original **** though. The MGW **** is too hard. I prefer the leather wrap of the OEM ****.
To Mgw ftw!!!
Old May 8, 2015 | 07:16 PM
  #38
j5m's Avatar
j5m
Installed the MGW last night. Love it. Much better feeling. Also think there might be less road noise now.
Their YouTube videos made everything super easy, even for a mechanically challenged person such as myself.
Old May 8, 2015 | 11:15 PM
  #39
Pounder's Avatar
Pounder
1/4 mile/AutoX
I never had a problem with hitting 3rd but sometimes hit 2nd when going to 4th. I found that it would happen when hard acceleration when getting on the E-way and going to the left lane the car was pulling me to the left and thus I was pulling the shifter left. I also read a post where someone posted when going to 3rd. just push the shifter forward and it will never miss. 5th I find you do need to push to the right some!!!! My 2 cents!!!!!!
Old May 9, 2015 | 07:52 AM
  #40
XXXLTRP's Avatar
XXXLTRP
Hmmm... Makes me wonder if I want to try the MGW. I have the Hurst in now. I like the adjustable positive stops, prevents over rowing and damaging something. I like the new MGW flat stick design with the new lower box, but no positive stops makes me hesitant to change it out. I don't worry about the effort it takes to shift, my old clutch car was a Jerico 4 speed and Long shifter.
