New LED rear-fog option for Euro cars.
Supporting Vendor
Currently exported C6 corvettes require amber turn signals and rear-facing fog lights to comply with euro standards.
After a successful test and first customer approval, Radioflyer Innovations is happy to announce that we will soon be offering a new rear-facing fog option. The reverse lights are replaced with a bi-color white/red LED bulb that functions as both a fog light and reverse light with a simple wiring tap and replacement socket for the reverse light housing.
It perfectly complements our eagle eye LED tail lights with the Euro "Centerpoint" (Amber turn signal) modification.
Here are some preliminary test photos from our customer in Germany:
Reverse light function:
Fog function:
Fog function:
streetstrip (04-08-2020)
Supporting Vendor
c6 euro fog lights
How do you switch the 'fog light' function on?
Supporting Vendor
Supporting Vendor
You may need to also install a fuse and relay for the rear fog lights in the factory locations in the passenger foot well fuse box. On US spec cars, I believe this circuit is linked to the fog lights (need supporting documentation) but may also require BCM re-programming.
On the rear harness connector (on the frame rail under the passenger tail lights) there should be an orange wire on the upstream side of the connector. This is the rear-fog 12v+ power wire.
Supporting Vendor
PMs disabled.
Email: radioflyer97@gmail.com
Note 2005 cars will require running a wire from the OEM front fog light fuse to power the rear fog lights.
Hi
I know its an old post but trying to get more information how to wire the rear fog lights into the BCM. Anyone has done this with this harness and could give
more detailed instructions?
Thanks a lot.
Thanks a lot.
Supporting Vendor
My understanding is that installing the C6 euro harness, the rear fogs get power from the "H" pin on the rear harness terminal. The BCM would need to be re-programmed, and the mult-ifunction switch would need to replaced with an e-code one for rear-fogs.
Alternatively, you could just run the rear fogs off the front fog circuit by jumping the fuses.
