Kenwood Double Din Deal of the Week- DNX772 with FREE JL Audio Speaker upgrade!
Former Vendor
I keep getting emails and messages all the time on what will be the next hot buy on double din units.
So with that in mind here you go.
This weekend 10/26 to 11/1
I have for you the Kenwood DNX772 Package on Sale
WITH FREE JL AUDIO SPEAKERS!
You will get for only
$949.99!
1- Kenwood DNX772
YOUR BEZEL SENT TO US FOR MODIFICATION
INTO A DOUBLE DIN
TEXTURED BLACK WITH ASH TRAY
1- ROEMVET1 HARNESS
1- GM ANTENNA ADAPTER
1- SET OF BASIC INSTALLATION BRACKETS
PLUS!!!
FREE JL AUDIO TR SERIES
SPEAKER UPGRADE KIT!
INTO A DOUBLE DIN
1- ROEMVET1 HARNESS
PLUS!!!
CLICK HERE TO ORDER YOURS
Kenwood Double DIN NAV Navigation System With Bluetooth And HD Radio, Model DNX772BH
The Perfect Entertainment Package
iDataLink Maestro Rr
When an iDataLink Maestro Rr is connected to a compatible Kenwood receiver, it provides a seamless interface with factory infotainment features such as Satellite Radio, USB Media Player, Bluetooth hands-free and music streaming. The unit then displays the onboard features of the vehicle information.
Wireless Mirroring Ready
Your smartphone display can be transmitted to your Kenwood receiver wirelessly by connecting the optional KCA-WL100 Miracast dongle.
True Mirroring with HDMI / MHL
Connect your smartphone via HDMI/MHL to mirror its display on your receiver. Operate your smartphone applications with the receiver touch panel.
Bluetooth Technology
2 Phones Switchable Hands Free
While you are connected through Bluetooth, by a touch of a button you can switch between two phones. Answering, calling or searching your phonebook on your phone is made simple.
Voice Dialing / Siri Eyes Free
The Kenwood receiver will allow the voice dialing feature found on most smartphones to work through Bluetooth.
Advanced Navigation
Guidance by Garmin
Equipped with the industry standard Garmin navigation system, offering a variety of display options to make your driving easy.
INRIX Traffic
You can get 2 years free access to INRIX traffic information, offering real time traffic information as well as parking, fuel services, weather and much more.
Kenwood Drive APP
By selecting the Kenwood Smartphone Control App on the APPS Source screen, pre-selected apps suitable for use while driving are displayed as easy to select large icons, such as Waze, Kenwood Music Control, and TuneIn Radio for Android.
Parking Assistance
Parking guide lines appear even on third party rear view cameras, making parking easy and safer.
Sound Quality
Drive EQ
Road noise is the enemy of all audio systems found in vehicles. The inherent frequencies of road noise masks a wide range of the audio signal found in music, and this is the reason Kenwood engineers developed Drive EQ. Drive EQ boosts specific frequencies in the audio signal to compensate the negative impact of road noise.
Graphic EQ / Time Alignment
Use the graphic equalizer to tailor the sound quality to your unique tastes. Additional sound contouring is available with the Time Alignment feature, designed to provide optimal and balanced sound performance.
Key Features:
6.95 inch Wide VGA Color LCD Display with LED Backlight
Motorized Reverse Tilt & 5 Step Tilt Angle Adjust
Touch Panel Control , Variable Key Illumination
Built -in HD Radio
HDMI / MHL Connection with Optional Cable
Bluetooth Built-in (Hands-Free Profile / Audio Profile(A2DP) / SPP)
Features:
General
Touch Panel Control, Variable Key Illumination
Background Customize (JPEG x1), Display Customize (Color Coordinate)
Picture in Picture (Visual Source in Navi)
Multi-Language Menu & Tag (21 Languages (English, Spanish, French and others)
Audio/Video Features
Maximum Output Power : 50W x 4 (MOSFET Power IC)
3 Preouts (2V)
HDMI / MHL Connection with Optional Cable *1
1 Rear AV Input (RCA & Mini-jack), 1 Rear AV Output (RCA: Video / Mini-jack: Audio)
1 RCA Video Input for Rear View Camera
Sound Excellence DSP (7 Band Graphic EQ / Digital Time Alignment / Space Enhancer
Sound Realizer / Sound Elevation / Bass Boost / Loudness / Drive EQ)
Installer & Backup Memory (Store & Backup Audio/Video Settings)
Navigation Features
Built-in Garmin Navigation
Lane Assist, Multiple Route Preview, ecoRoute, My Trend
SD Card Slot (for Map Update Only)
Parking Guide Line
DVD/CD Features
DVD Video/±R/RW Playback, MPEG 1/2 Video Playback
VCD Compatible
MP3 / WMA / AAC Playback, CD-R/-RW Playback
CD Text Ready, Repeat / Random Play
24 Bit D/A Converter
Tuner Features
Built-in HD Radio
Sirius XM Ready
FM / AM 24 Station Presets (FM x 18, AM x 6)
RBDS with Radio Text Plus
AME (Automatic Memory Entry), Up/Down Seek Tuning
USB Features
USB Interface x 1 (Rear)
MP3 / WMA / AAC / WAV / FLAC Playback
MPEG 1/2 Video / MPEG4 / H.264 / WMV / mkv / JPEG Playback
iPhone/iPod USB Direct Connection with Optional Cable *2
iPhone App Mode
Pandora / iHeart Radio App Ready (iPhone App)
External Media Control Features
Bluetooth Built-in (Hands-Free Profile / SMS (Receiving Alert, Text Display, Sending) / Audio Profile (A2DP) / SPP /AAC)
Bluetooth Auto Pairing for iPhone
Voice Control with iPhone using Siri
Pandora / iHeart Radio App Ready (Android App : A2DP/SPP/Multi Profile)
OEM Remote Control Interface
iDataLink
Specifications:
Monitor Section
Picture size: 6.95inches (diagonal) wide
W x H: 6-3/16 x 3-3/16 inch
Display system: Transparent TN LCD panel
Drive system: TFT active matrix system
Number of pixels:
1152000
800H x 480V x RGB
Effective pixels: 99.99%
Pixel arrangement: RGB striped arrangement
Back lighting: LED
DVD Section
D/A Converter: 24Bit
Audio Decoder:
Linear PCM
Dolby Digital
MP3 / WMA / AAC
Video Decoder: MPEG1 / MPEG2
Wow & Flutter: Below Measurable Limit
Frequency Response:
96k Sampling: 20 - 20,000 Hz
48k Sampling: 20 - 20,000 Hz
44.1k Sampling: 20 - 20,000 Hz
Total Harmonic Distortion (1kHz): 0.010%
Signal to Noise ratio: 98dB(DVD-Video 96k)
Dynamic Range: 98dB(DVD-Video 96k)
DISC Format: DVD-Video / VIDEO-CD / CD-DA
Sampling Frequency:
44.1kHz / 48kHz
96kHz
Quantifying Bit Number: 16 / 20 / 24bit
USB I/F Section
USB Standard: USB2.0 High Speed
File System: FAT 16 / 32
Maximum Power Supply Current: DC5V=1A
Audio Decoder: MP3 / WMA / AAC / WAV / FLAC
Video Decoder: MPEG1 / MPEG2 / MPEG4 / WMV / H.264 / mkv
SD Section
SD Standard: SD / SDHC
Compatible File System: FAT 16 / 32
Capacity: Maximum: 32G Byte
Data Transfer Rate: Maximum 24MB/sec
Bluetooth Section
Technology: Bluetooth Ver3.0+ EDR
Frequency: 2.402 – 2.480 GHz
Output Power: +4dBm (MAX),0dBm (AVE) Power Class 2
Maximum Communication range: Line of sight approx.10m(32.8ft)
Audio Codec: SBC / AAC / MP3
Multi Profile support: Multi Profile
Profile:
HFP (V1.6) (Hands Free Profile)
SPP (Serial Port Profile)
A2DP (Advanced Audio Distribution Profile)
AVRCP (V1.4) (Audio/Video Remote Control Profile)
HID (Human Interface Device Profile)
PBAP (Phonebook Access Profile)
GAP (Generic Access Profile)
HDMI
HDMI: Type-A
MHL
Supported Version: MHL2
Maximum Power Supply Current: DC5V=900mA
DSP Section
Graphics Equalizer
BAND: 7Band
frequency(Hz) (BAND1-7,1-13): 62.5/160/400/1k/2.5k/6.3k/16k
Gain: -9/-8/-7/-6/-5/-4/-3/-2/-1/0/1/2/3/4/5/6/7/8/9[dB]
2Way X'Over
HIGH PASS FILTER Frequency: Through/50/60/80/100/120/150/180/220[Hz]
SLOPE: -6/-12/-18/-24[dB/Oct.]
LOW PASS FILTER Frequency: 50/60/80/100/120/Through[Hz]
Position
Front / Rear /Subwoofer Delay: 0 - 20.0ft (0.07ft Step)
Gain: -8 to 0dB
Subwoofer Level: -50 to +10dB
Digital FM
Frequency Range: 87.9MHz - 107.9MHz
(Frequency step): (200kHz)
Frequency Response: 20Hz - 20kHz
S/N: 75dB (STEREO)
Digital AM
Frequency Range: 530kHz - 1700kHz
(Frequency step): (10kHz)
Frequency Response: 40Hz - 15kHz
S/N: 75dB(STEREO)
FM
Frequency Range: 87.9 MHz - 107.9 MHz
(Frequency step): (200 kHz)
Usable Sensitivity: 7.2 dBf
S/N:30dB (K) / 26dB (E): 0.8 µV / 75 Ohms
Quieting sensitivity: 10.2 dBf
S/N:50dB (K) / 46dB (E): 1.13ìV / 75Ohms
Frequency response: 30Hz - 15kHz
S/N( dB): 75 dB(MONO)
Selectivity: Over 80 dB(±400 kHz)
Stereo separation: 45 dB(1 kHz)
AM
Frequency Range: 530 kHz - 1700 kHz
(Frequency step): (10 kHz)
Usable Sensitivity: 28 dBµ
Video
Color system of external video input: NTSC / PAL
External video input level (Mini jacks): 1 Vp-p / 75Ohms
External audio max input level(Mini jacks): 2 V / 25kOhms
Video Input level (RCA jacks): 1 Vp-p/75Ohms
Video Output level (RCA jacks): 1 Vp-p / 75Ohms
Audio Output level (RCA jacks): 1.2 V / 10kOhms
Audio
Maximum Power (Front&Rear): 50Wx4
Typical Power Output (Front&Rear): Full Bandwidth Power (at less than 1%THD) 22Wx4
Preout level(V): 2V / 10kOhms
Preout impedance(Ù): =< 600Ohms
Speaker Impedance(Ù): 4-8 Ohms
Navigation Section
Receiver: High-sensitivity GPS receiver
Receiving Frequency: 1575.42MHz (C/A code )
Acquisition Times: Cold: 29 seconds(typ) All satellites at -130dBm Without aiding
Update Rate: 1/second, continuous
Accuracy: Position: < 2.5meters,CEP, at -130dBm
Accuracy: Velocity: 0.1meter/sec
Positioning Method: GPS
Antenna: External GPS Antenna
General
Operating Voltage: 14.4V(10.5V to 16V)
Maximum Current Consumption: 10A
Installation Dimensions (W x H x D):
182mm x 112mm x 156mm
7-3/16 x 4-7/16 x 6-1/8 inch
Operational Temperature Range: -10°C to +60°C
Approximate Weight:
Unit: 5.51 lbs
Shipping: 7 lbs
Warranty Information:
Manufacturer Warranty (authorized online retailer): 1 Year Parts And Labor
Advanced Navigation
Guidance by Garmin
INRIX Traffic
Kenwood Drive APP
Parking Assistance
Sound Quality
Drive EQ
Key Features:
Built -in HD Radio
Features:
General
3 Preouts (2V)
Navigation Features
Parking Guide Line
DVD/CD Features
VCD Compatible
Tuner Features
Built-in HD Radio
Sirius XM Ready
USB Features
iPhone App Mode
iDataLink
Specifications:
Monitor Section
Number of pixels:
1152000
800H x 480V x RGB
Back lighting: LED
DVD Section
Audio Decoder:
Linear PCM
Dolby Digital
MP3 / WMA / AAC
Frequency Response:
Sampling Frequency:
44.1kHz / 48kHz
96kHz
USB I/F Section
SD Section
Bluetooth Section
Profile:
HDMI
HDMI: Type-A
MHL
DSP Section
Graphics Equalizer
BAND: 7Band
2Way X'Over
Position
Gain: -8 to 0dB
Digital FM
S/N: 75dB (STEREO)
Digital AM
S/N: 75dB(STEREO)
FM
AM
Video
Audio
Navigation Section
General
Approximate Weight:
Unit: 5.51 lbs
Shipping: 7 lbs
Former Vendor
dont like this radio option?
Then just call me and we will hook you up!
Dennis
608 854 2033
Dennis
608 854 2033
