Corvette Generation Question
Originally Posted by Ambalanche View Post
I could be wrong but I thought the "C" designations began with the C5 and reverted back from there.
- prior to that, i remember solid axles, mid-years, and late models. when the 84's came out, 68-82's became known as "sharks", and the 84 generation were late models, then in 97, corvettes became c5's, and since then, the C-generation thing took over. i still refer to early corvettes as solid axles, mid-years, and sharks - later corvettes as C4's, C5's and C6's.
Chevrolet Corvette C6 Z06
Y bodies built after 1964 can be identified by the inclusion of the Y as the fourth character in the Vehicle Identification Number, or VIN. Only two Y-body cars have been produced in this second group:
2004–2009 Cadillac XLR
1984–present Chevrolet Corvette
The Y-Body has a rear-wheel drive, front-engined V8 layout, accommodating either a small block Chevrolet V8 (such as an LT4 or LS1) in the Corvette, or the 32-valve DOHC Northstar V8 in the XLR. The Y-Body also has 4-wheel independent suspension. Like a standard rear-wheel drive, front-engined chassis, the Y-Body's V8 engine is longitudinally mounted, but unlike many such cars, the Y-Body incorporates a rear-mounted transaxle (1997-present) instead of a transmission mounted directly to the engine. Power is transferred to the transaxle via a torque tube. The transaxle is offered in both 6-speed automatic and 6-speed manual versions. As of 2015 the Y platform is considered as the sole perimeter frame automobile in production (the perimeter frame has an integrated endoskeleton which serves as a safety cage).
GM's Kappa platform was inspired by the Y-body. The distinctive feature of both platforms is the backbone central-tunnel design.
