air leak
air leak
Brought this C5 home in Dec and something didn't feel right. There was a looseness in the rear end. DIC eventually showed rt rear tire low. Added air and then the same thing again. Took it to a Goodyear tire store and this is what they found in my tire. The smaller piece was rattling around in the wheel, the larger one stuck in the tire. I thought it was a wheel bearing. Maybe the original owner did too, which may explain how I got it. Rear wheel bearings are expensive to replace. Anyway, I can't believe how much better it feels. Tire repaired, balanced, what a difference.
Received 19,225 Likes
'20-'21-'22-'23-'24
That would certainly cause a loss of air in the tire. Good that you finally found the problem.
Received 3,812 Likes
That's a tire plug reamer.. apparently the former owner fixed that tire using a patch kit and broke the reamer off in the tire, or forgot about it and broke it off. leaving one part in the tire cavity, and the other in the tread.
garebear (02-12-2016)
