why do i need a catch can?
Bill aka ET
I have a stock PMGR starter on the 565 in my Cole drag boat and it spins the BBC like the plugs are out.
PMGR stands for permanent magnet gear reduction, and my 99 crew cab dually also has the same starter, stock.
While a catch can for the PCV system MAY be of some benefit, an after market starter will provide ZERO benefits to the purchaser.
Bill aka ET
Like I said, I know why some people post these irreverent comments. But to offer it up would only serve as petty. These few distractors are in the very small minority, and it has something to do with their own personal low self esteem.
Thanks again
Bill aka ET
Thanks again
Bill aka ET
that stock plumbing that goes from the valley to the manifold was idotic. The motor may run for 5000000000000 miles, but that doesn't mean it cant run better or more efficient.
In the grand scheme of things, in a naturally aspirated engine designed for 100k miles, a catch can is an absolute waste of time, and would have upped production costs by millions. Engineering isn't all about making the best product possible, but the best product possible at a given price that's only supposed to last for a given amount of time. That means if something is not necessary to get the engine past 100k miles and doesn't increase power, it's probably not gonna be on there.
This is especially true when cutting costs to make a corvette as affordable as it is compared to other cars with similar performance. Just look at the harmonic balancer for example. I guarantee you will not find one less than 5 years and 100k miles that has separated. This isn't bad engineering. It's engineering within the manufacturing constraints. If you don't like it, don't buy old cars that are outside their warranty period. You will find these kind of things on just about every single car.
If the c5 had all the bells and whistles that everyone on this forum says it should have had, half of us probably wouldn't be driving one due to the cost.
Personally, I don't have a catch can. I plan on installing one eventually especially since I just had my heads and intake off over the winter and cleaned everything up all nicely.
So that's one data point with one engine.
Haters will always hate... no doubt about that, but you have to ask yourself how many hours these wanna be automotive engineers all spent in the Corvette design studio.
millions of dollars spent on research and development of the C7 Z07 and still no catch can...after 63 years. Do you really think a 15 dollar ( cost to manufacture oil catch can ) would be removed from the design if it was necessary? Silly arguments from very clueless people. These cars can go 400K .. but in the hands of these pseudo engineers, their cars seem to have issues. AS I say to many people who PM me, I am NOT a tuner. I don't give tips on re engineering. Everything GM does is backed by many hours of test to fail and also non destructive testing. Is the car perfect, Hell no ! but if it was. most people here could not afford it. Dave wanted reliability and integrity built in. If a catch can added anything necessary to the design it would be there. The high water mark for the budget was in the drive train...Dave made sure of that, its also the reason why the seats, the sound system etc are not top notch. The other consideration is weight. Any Revision ( Rev.) to an existing design had to have a measure of reducing weight, and still stay within the budget or it was not accepted. I have so much insider information on the development of this car that these haters, are just plain clueless.
Lastly, as I've said many times, be very careful who you listen too on this forum.
Bill aka ET
Bill aka ET
to bad they didn't do all that testing on the ls7
Google is your friend, knowledge is power, the invention of the system is quite intriguing if you ask me...born from necessity, then like many other things, the man decided it was needed on consumer vehicles...progress!
With that said, PCV systems have been around since the 60s, so no you do not NEED one to operate your vehicle as the factory intended.
https://www.corvetteforum.com/forums...ver-today.html
Bill aka ET
As usual you cannot comment with trying to denegrate others.
