Passenger Headlight
Old Mar 1, 2016 | 04:13 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Passenger Headlight
Turned on the lights the other night and the passenger light did not go up all the way....got out and you could lift it up but it would not stay up...Is it the gear problem or something else I need to check ??
Jim
Old Mar 1, 2016 | 05:52 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
The gears go bad but the good news is you can take out the gear and turn it 180 degrees or replace it. Try turning the top of the motor that will open and close it manually, it's like a ****. If you're going to rebuild or replace do both.
Old Mar 1, 2016 | 08:46 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Gears
Thanks for the info I was hoping for an adjustment now I need to wait until it gets a little warmer to pull the motors and replace the gears.
To Passenger Headlight
