Any regrets on C6/Z06 shock upgrade?
I'm dropping off my base 02 at the dealer's this thurs to get some work done(oil change/inspection/tire balance etc..) and they are also going to install the new shocks and Z51 sways that so many have upgraded to but I need some reassurance as I'm getting some cold feet on doing the install. The whole job including an alignment is going to run about 350.00 so if I don't like the ride I'll be kicking myself and ponying up another 3-4 hundred to swap them back.
The car has 95000 miles on her and I have to avoid the potholes around here to keep my kidneys in place--quite a jolt when I hit them so I probably need new something or other.
Can anybody dissuade me due to their experience on this or am I going to be ex-tactic with my new suspension? It seems that a lot of you already had Z06's or Z51's and was happy with the change but what about you base C5 owners?
Help me please--I'm tired of breathing in a paper bag...
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Interested too
Location: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Great improvement. I have definitely noticed a difference in how it rides with these shocks. Since my car is lowered an added improvement was a bump-steer kit as well. Although, I would prefer coilovers, I have no regrets with a C6 Z06 shock set-up.
Thanks for the reply--Since your's was lowered did you notice any ride height change? I'm not sure if mine has been lowered or not but I like the height it is now and don't want the 4x4 look after the install.
Honestly, I did not see any difference in ride height, after going with the new shocks but, that is my car. You might notice a slight difference after the shocks are just put on but, that's because the shocks may need a little time to compress. I'm speculating that your car is not lowered, so the new shocks are not having to be restrained by a lowering kit. If after some time passes and you don't like the height, a lowering kit is a relatively cheap fix. Just because you put a lowering kit on it, doesn't mean you have to slam it. There's a happy medium in there as well. Hope I was able to clarify some concerns for you.
I'll be sure & post my thoughts after all is done.
Pro Mechanic
I did this mod several years ago...by keeping the base springs, I kept decent compliance in the suspension to deal with these sh*tty MI roads. Car now corners flat as a pancake...love it!
Thanks for the input.
lonerider2002 (03-14-2016)
