Air Bag Question
Old Jun 24, 2016 | 10:45 AM
31ECHO's Avatar
31ECHO
Default Air Bag Question
The air bag icon does not appear on the dash when I turn on the key. Checked the fuse & it is good. Is it possible the dash light is out? I assume the other possibility is the AB is kaput.
Old Jun 24, 2016 | 12:34 PM
31ECHO's Avatar
31ECHO
Originally Posted by 8VETTE7
Perhaps pulling the codes and looking at what codes show up under 58 - SDM will shed some light on the status of the airbag. There are about a dozen possible codes.
If you have never pulled codes on your C5 here is how:
https://www.youtube.com/watch?v=SviRjIsy9G4
OR
http://www.c5forum.com/ayc/dtcdic.php
No codes for 58. Showed up as 58-8DM not SDM.
Old Jun 24, 2016 | 06:41 PM
Vanover's Avatar
Vanover
What fuse did you check?mine is doing the same thing.
Old Jun 25, 2016 | 11:18 AM
Vanover's Avatar
Vanover
Back of your Owners Manual has a layout of both fuse boxes. It is clearly labeled. Fuse #16.
Checked 16,it good.i guess there's no easy way to check the bulb but to pull the cluster.all the other lights work.
To Air Bag Question
