Buying a new Corvette 17 years after the fact
#262
Almost could use some spacer on the rear! Maybe 1/2"?
#263
yeah I agree, the rear looks a little funny compared to the front.
I'm going to wait though and make sure these wheels fit around the new brakes first though
#264
I have a pair of 1" bolt on spacers that will work perfect for you when you're ready.
#265
We'll see
I'd really like a set of CCW C10s (if I can't get the z wheels around the brakes)
But those speedlines on Ebay are calling my name!
#267
So last night I went ahead and ordered a front caliper. I need to make sure these things don't look like garbage, and this way I'll be able to test the wheel fitment.
I know 18s are plenty possible (CCW, Forgestar etc), but I haven't seen anything about c5z wheels over them. I think however a spacer would fix any issues (I hope).
I'm also 99% sure I have rotors figured out. Still more than I want to spend at $1500 for all 4, BUT, they are off the shelf DBA rotors made specifically for OEM brembo hats. I still need to measure the hat PCD to be sure, but I think this will take care of it in a safe and more OEM style. (as opposed to having Coleman custom make them)
390x34mm front (same spec as the RB iron conversion)
and 380x32mm rear
and 380x32mm rear
#268
and 380x32mm rear
and 380x32mm rear
#269
The z06/GS brakes were the plan when I first bought the car.
But then I realized I don't want a caliper designed for 6 individual pads.
I wanted to do something different, and the only C5 with ZR1 brakes (that I know of) uses the CCB rotors, which is not a practical solution in my opinion, unless money is falling out of your pockets.
My goal is to do this within a reasonable budget with common parts.
While I certainly recognize that this is hilariously too much brake for my car (or almost any car driven on the street),
I'm also doing it because I think its cool, simple as that.
My first car, a 1990 Toyota Corolla wagon, had 14" wheels.
Now I'll have 15.5" brakes.
I think doing this will also open up the avenue for a lot of other people looking into BBKs in a similar budget, assuming I'll be able to complete this for the expected ~$2300 dollar price tag.
#270
Thats a great looking car Mike!
Check these out:
http://www.corvettegarage.com/c6-z06...rake-pads.html
#272
Things have been pretty pitiful progress wise
We bought a new house, but haven't had any luck selling the old one yet. So that means no fun money.
On the plus side, I think I have cracked the code with regards to a true budget (relatively) ZR1 brake setup.
PowerStop has been very helpful with my questions, and I have identified the necessary rotors (hopefully). These are already produced for another platform, and will currently require a hat swap, but I'm hoping by my completion of this project, they may start offering a ZR1 specific solution.
