13 year old Goodyear run flats safe? - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 03-16-2017, 03:10 AM
Rjwz2
CF Member
Default 13 year old Goodyear run flats safe?
I pretty much know the answer to this question but just want to hear it from you guys. Got a 03 coupe with only 16k miles and they have the original F1 run flats on them. They still have a lot of tread but from what have been reading they probably are unsafe.
I didn't know that tires have an age life until getting this car recently.
Thoughts?
Thanks,
Rob
Rjwz2 is offline
Old 03-16-2017, 03:29 AM
pewter99
Admin
Support Corvetteforum!
pewter99's Avatar
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
no way I would drive on them......
pewter99 is offline
Old 03-16-2017, 03:39 AM
chain_5001
CF Senior Member
No. Go get yourself some new tires. If you run a set of 13 years old tires there is no probably about it. You will regret it.
chain_5001 is offline
Old 03-16-2017, 03:43 AM
pewter99
Admin
pewter99's Avatar
gotta drive your car more.....I was pissed when I had to dump a set of tires last year due to age and they had 40% tread left
pewter99 is offline
Old 03-16-2017, 03:47 AM
Rjwz2
CF Member
I just got it last year. Too bad because it has a lot of tread left. And I feel your pain as I got to spend over $1100 for new onews.
thanks.
Rjwz2 is offline
Old 03-16-2017, 04:11 AM
Tsumi
CF Senior Member
Tsumi's Avatar
If you're okay with not getting runflats, there are lots of cheaper options.
Tsumi is online now
Old 03-16-2017, 07:41 AM
Rob 02
CF Senior Member
Rob 02's Avatar
Loan them to me and I will burn the tread off for you.
Rob 02 is offline
The Following User Says Thank You to Rob 02 For This Useful Post:
Movie Muscle (03-18-2017)
Old 03-16-2017, 08:03 AM
runner140*
CF Senior Member
runner140*'s Avatar
Get yourself a set of non-runflats. You'll love the difference. Go to the web site...TireRack.com They are a Forum supporter with great prices and service.
runner140* is offline
Old 03-16-2017, 08:07 AM
MAD IN NC
CF Senior Member
MAD IN NC's Avatar
Crowd Plow For Now
No way... Burn em off and replace. Peace of mind worth it if you go more than 2 miles on a trip
MAD IN NC is offline
The Following User Says Thank You to MAD IN NC For This Useful Post:
Old 03-16-2017, 10:10 AM
Jeff T.
CF Senior Member
Jeff T.'s Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18
Absolutely safe!
Name:  Tire Swing.jpg
Jeff T. is offline
The Following User Says Thank You to Jeff T. For This Useful Post:
Old 03-16-2017, 10:22 AM
8VETTE7
CF Senior Member
Originally Posted by Jeff T. View Post
Absolutely safe!
Attachment 48073499
They are safe for this purpose!!
8VETTE7 is offline
Old 03-16-2017, 10:27 AM
JEH03Vette
CF Senior Member
JEH03Vette's Avatar
13 year old rubber? I wouldn't drive on them.
JEH03Vette is offline
Old 03-16-2017, 10:31 AM
calvins
CF Senior Member
calvins's Avatar
Location: Rotonda West, Florida '03 Elec. Blue M6 Coupe
Oldtimer
Wanna bet your life on 'em? Have some fun spinning them and then put some good non-run flats on and you'll be MUCH happier.
calvins is offline
Old 03-16-2017, 10:34 AM
r0bd
CF Senior Member
r0bd's Avatar
r0bd is offline
Old 03-16-2017, 11:49 AM
C5Txfan
CF Senior Member
C5Txfan's Avatar
Might be safe to drive a mile or so to a store or friends house, church or someplace like that - but not much more than that or very fast !
C5Txfan is offline
SenorZ06_Tacos
CF Member
SenorZ06_Tacos's Avatar
Nuff said, get yourself a set of Bridgestone Potenza RE760.
SenorZ06_Tacos is offline
Old 03-16-2017, 12:48 PM
knewblewkorvette
CF Senior Member
knewblewkorvette's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-18-'19
No, the pros at Tire Rack says car tires are only good from 6 to 10 years, depending on how they are used.
http://blog.tirerack.com/blog/hunter...old-is-too-old
knewblewkorvette is offline
Old 03-16-2017, 12:54 PM
Sydwayz
CF Senior Member
Sydwayz's Avatar
St. Jude Donor '18
Chuck 'em and go to normal tires. Skip the run flats and you will be miles happier.
Sydwayz is offline
Old 03-16-2017, 12:55 PM
keeso6z
CF Senior Member
I'm in the same boat. I have a 2006Z06 with the original Goodyear run flats with 2,500 miles. The tires look fine from the outside and have lots of tread on them, but looks can be deceiving. I read that tires should be replaced after 10 years as they could be dry rotted. I think it also depends on where they were stored. If in a climate controlled garage for example, they will last longer. I need to do something with mine sooner or later and will go with Michelin run flats PSS.
keeso6z is offline
Old 03-16-2017, 01:17 PM
8VETTE7
CF Senior Member
Climate controlled garage or not the rubber hardens with age and traction will be all but non existent and tires will heat up much faster and get hotter as the rubber tends to not want to flex once it hardens.
8VETTE7 is offline
Quick Reply: 13 year old Goodyear run flats safe?
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
