2003 Pax Power Seat Problem, Need Help Please.
Before I dig in too deep I figured someone else may have had the same problem.
The seat functions all work except forward and backward. When activating the switch in both directions, there is an click sound similar to a relay. But no joy on the seat moving.
Ultimately, I have to get the seat moved forward to access the rear mounting nuts. The sea is going to be replaced soon.
Is there a way to manually move the seat forward?
Searching didn't yield anything to help....
I tried putting power direct to the motor. That was to no avail either. Apparently it drew a large amount of amps as my jumper box started squawking and giving me a low power indicator....
KCK8766 (03-30-2017)
