[Z06] Ticking sound in engine....
Old Sep 26, 2002 | 03:13 PM
BLT2SPD's Avatar
BLT2SPD
Default Ticking sound in engine....
I notice there is a mild ticking sound coming from the right side of my engine. It seems to be more prononced now but maybe it's just me because I'm aware of it. It's very noticable when I let of the throttle and am costing. Sounds very much like a lifter to me. I took it to my local dealer in Elk Grove and told the service manager what I thought. They drove it and wrote on the service sheet that it's a "characteristic" of corvettes and no repair is needed. I think their full of *&%#. Does everyone else have this noise in their car? :confused:
Old Sep 26, 2002 | 03:26 PM
edv2122's Avatar
edv2122
Default Re: Ticking sound in engine.... (BLT2SPD)
Mine does it and I think they all do it. I have read threads on this forum and other Z forums and it seems to be normal and nothing to worry about. :cheers:
Old Sep 26, 2002 | 03:48 PM
shaky's Avatar
shaky
Mine has a ticking sound that I notice from time to time. May others have commented on the ticking noise as well. Some on the forum say lifter some say injector. I have choosen to write it off as a characteristic.
Old Sep 26, 2002 | 04:13 PM
yelloz06's Avatar
yelloz06
Default Re: Ticking sound in engine.... (edv2122)
:yesnod:
:cheers:
Old Sep 26, 2002 | 04:18 PM
don527's Avatar
don527
Default Re: Ticking sound in engine.... (shaky)
http://forums.corvetteforum.com/zerothread?id=383282
dunno if it applies but you might wanna check because you mention the noise only coming from one side of the engine/cylinders.
normally, to notice a light ticking is normal... i thought it was a characteristic of the cams/valvetrain in the '01s and '02s compared to the ls1s.
[Modified by don527, 10:46 PM 9/26/2002]
Old Sep 26, 2002 | 04:35 PM
jerryv's Avatar
jerryv
There's been a lot of discussion about what the noise might be ... but wide consensus that it's there in most of our cars and is not worth worrying about.
Old Sep 26, 2002 | 09:32 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
I have the same noise on my 03 A/E coupe. It goes away at WOT. :D :D :D
Old Sep 26, 2002 | 11:09 PM
stevebc5's Avatar
stevebc5
Default Re: Ticking sound in engine.... (Another Yellow)
Could it be coming from the front part of the tranny? BOTH my front and rear transmission (whatever you call it) ticks........ LOUD :yesnod:
Old Sep 26, 2002 | 11:28 PM
Power Shifter's Avatar
Power Shifter
Default Re: Ticking sound in engine.... (stevebc5)
The ticking in my car IS the valve train, not injectors. If you lift the throtle quick does the ticking taper off? that's valve noise. If it cuts of more instantly it might be injector noise. Either way probably "normal" Ric
Old Sep 27, 2002 | 12:01 AM
TeamZ06's Avatar
TeamZ06
Default Re: Ticking sound in engine.... (Power Shifter)
the dealer wasn't BS'ing this time; they really do all do that, or something like that .. :)
Old Sep 27, 2002 | 12:15 AM
CALVette's Avatar
CALVette
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Ticking sound in engine.... (TeamZ06)
Mine only does it when I listen for it. :D :rolleyes:
Old Sep 27, 2002 | 02:45 AM
BLT2SPD's Avatar
BLT2SPD
Don't think so, because it still does it when not in gear
Old Sep 27, 2002 | 02:49 AM
BLT2SPD's Avatar
BLT2SPD
Default Re: Ticking sound in engine.... (Jerry Velders)
Do you notice it more pronounced on one side of your engine?
Old Sep 27, 2002 | 11:52 AM
Tom T.'s Avatar
Tom T.
Mine takes a lickin' and keeps on tickin'. Oh well, worked for the OLD Timex commercials.
TT :lol:
Old Sep 29, 2002 | 01:35 PM
Closer_2001's Avatar
Closer_2001
Check for...
1. Rocker losing its bearings
2. Slightly Bent Pushrod
3. Slightly Bent Valve (May require removal of heads)
Been there, done that, service manager told me I was nuts also. That was after I figured out they only repaired one bank the first time around.
Upgrade to LS6 valvesprings as the stockers can float at 5500 RPM. Yes, 5500 RPM.
Old Sep 29, 2002 | 09:07 PM
ShawnR's Avatar
ShawnR
Default Re: Ticking sound in engine.... (Closer_2001)
Mine has a real quiet ticking sound too.
Old Oct 14, 2002 | 09:39 PM
kevette's Avatar
kevette
I believe all dealers will tell you it's a Corvette charateristic, I took my 00 FRC in and they told me it was valve clatter, typical Corvette noise. I said ok. :confused: :bs
Purchased and installed crane rocker kit(pushrods,studs,rockers,guideplates) and after installation, noise seemed to quiet down, still there but not as noticeable.
To Ticking sound in engine....
Old Oct 15, 2002 | 06:08 AM
Fast Lane's Avatar
Fast Lane
CI 3-4-5-6-7-8-9-10 Veteran
Default Re: Ticking sound in engine.... (ShawnR)
My 01 coupe didn't do this. The 02 does. It's quite muffled, I chose to ignore it after reading this and other posts. :chevy
Old Oct 15, 2002 | 07:58 PM
WOT99FRC's Avatar
WOT99FRC
Default Re: Ticking sound in engine.... (Fast Lane)
Some times I hear it if I listen for it, but then I hear the voices say floor it and it goes away. This is the most common solution to most of the C5's ailments.
Old Oct 15, 2002 | 11:13 PM
Obdoc's Avatar
Obdoc
Default Re: Ticking sound in engine.... (WOT99FRC)
This is normal. It is the valvetrain on the Z06. ;)
