Upgrading my C5
Upgrading my C5
I'm currently in the process of upgrading my ls1 C5. Has Cai, exhaust, and long tube headers. I will be soon adding either a 224 or 228 cam, Also plan on adding an ls6 intake and finally have the car tuned. Suspension wise just billstien shocks and upgraded sway bar. Are there any other upgrades to improve the already exciting driving of these cars? It's my first Vette so any opinions are appreciated. Wanting to keep it as a fun weekend driver.
Wontspeak (06-07-2017)
From what I've read the LS1 intake was retired after the 2000 engine model year and replaced with the LS6. If thats true then there is no need to buy an LS6 intake for 2001 and beyond. Is this correct?
^I think 2001 when all C5's got the the LS6 intake. After the Z06 came out.
As for the gears. The 3.15 is okay but if you are going to spend the money go with 3.42 gears. The gear swap is not a shade tree mechanic job and wont fit on a 2.73 carrier any way. You will have to swap the whole differential.
Received 19,298 Likes
'20-'21-'22-'23-'24
well update time, been tied up at work so been moving slowly, finally got my cam kit ordered. Ended up going with a texas speed 224r cam with new springs, psuhrods, lifters, timing chain and high flow oil pump, should have everything on in the next couple weeks, cant wait to get it all together I am going to be purchasing a stall, texas speed recommended a 2800-3000rpm, sound about right? and recommendations on which to buy and am i going to run into needing a tranny cooler? thanks
If you have money left in your budget some rebuilt 799 or 243 heads (same casting) would help things flow better. The 799's are sand cast and the 243's are die-cast. 799's can be purchased rebuilt for around $500-$550. I used a thinner .040" head gasket for higher compression and better quench for less detonation. The heads will probably increase the HP of your build by at least 30-40 HP.
Also having the '01-'04 intake (same as LS6) helps.
Received 1,254 Likes
2016 C5 of Year Finalist
Upgrade the heads.
Good luck.
