Replacing my a/c Compressor
Replacing my a/c Compressor and need some advice on what kit to purchase? Best price ?
My car is a 1997 C5 and this is the original a/c compressor that has went out! Thanks!!
This was the kit I used on my 01. Although Amazon says it doesn't fit, this kit fit without issue. I did the install with a friend. Made it a lil bit easier when installing the water pump. Be sure you are careful when removing the B-nut from the dryer. Also be sure to NOT OVERFILL the system of oil. The compressor showed up to my door had oil in it.
https://www.amazon.com/dp/B00JXYGA6W..._t1_B00JXYIE6G
directions for install
Received 3,866 Likes
2015 C5 of the Year Winner
Different Web site but a great how-to...
I'll be using this when I change mine out soon also.
http://www.digitalcorvettes.com/foru...d.php?t=153172
Red Robin (05-07-2017)
My ac comp weeps at the seam and I can't justify replacing because it rarely needs topping off but the leak is annoying me. At least there is a cost effective compressor out there to buy.
Thanks!
Great
Thank you for showing where to get a cost effective compressor kit and showing me your pictures! Helped my day of searching a whole lot easier
instructions did not come with new compressor
Hey there I just wanted to ask you a question? Did your new compressor come with instructions cause mine didn't?
No they did not. I used info I found in a few threads. I know my way around this motor too which helped. Try this...
https://www.corvetteforum.com/forums...-write-up.html
Click his hyperlink and you get what your looking for
Finally done!!
And I'm happy to report that the air is blowing Very Cold!! Thank You for your help!
mstromquist (05-22-2017)
A Big Thanks!!
Me and my husband finished installing my ac compressor, Accumulator, Orifice, o-rings and gaskets for the waterpump! My car is blowing some very cold air now!! My husband got the air blowing 43.4 degrees
Marc
97 C5 AC Compressor change out finally done!!
Well my husband and I finished installing my new AC Compressor, Orifice Tube, Accumulator and gaskets for the waterpump!! I appreciate all the help and answers to my many questions, it made the job a lot faster!
I'm gonna share some of the photos and yes I know I have a bad oil leak and yes we are going to be fixing it next...
By having good folks on here telling me where to get the best deal on the parts I needed for this job to the writeups that I was told to look at for installation I have to say really help us out!
You guys Rock!
You guys Rock!
Just wanted to say Thank You for showing me that write up and pictures for my install!! My husband and I worked on it yesterday and got everything replaced, New compressor, Accumulator, Orifice Tube, o-rings, and waterpump gaskets.
