spark plug wire sleeves installation question
When I changed the valve springs last Sunday I also replaced the plug wires. Two of the wires on the left side (#s 3 and 5) were very close to touching a metal tube that runs out of the exhaust manifold and curves and goes toward the firewall, so I installed heat shielding sleeves over all eight plug wires. Unfortunately, there were no instructions with them. They won't fit over or into the factory metal heat shields, so my question is: Do these sleeves butt up against the metal shielding tubes over the plugs or do they replace them? It appears they would work either way although I now have them installed in place of the metal shielding tubes. Rather then spend all day trying this or that, I thought I'd ask if anyone knows. Thanks in advance.
