LED problem, 2003 C5 Coupe (Merged)
Old 05-19-2017, 01:18 PM
GMANN1957
1st Gear
GMANN1957's Avatar
Default LED problem, 2003 C5 Coupe (Merged)
Hi All,
I decided to replace the DRL bulbs with LED's because they were also melting my lenses. So I installed the hyperflash unit after the ignition as the instructions called for. This fixed the hyperflash problem, but now the blinker indicators stay dimly lit and I have a drain on my battery whenever I use the blinkers or use the brakes! The battery drops from 14.4 to 13.5 in a matter of seconds! Any ideas?
Thanks!
Old 05-19-2017, 07:00 PM
MAC5
MAC5's Avatar
Originally Posted by GMANN1957
Hi All,
Thanks!
If your confident no wire shorts exist I'd try flipping the DRL bulbs in the sockets. Do one side at a time. Might also be a defective blinker relay.
Old 05-19-2017, 10:24 PM
FX VETTE
FX VETTE's Avatar
Received 1,679 Likes on 1,182 Posts
Where did you get the DRL bulbs and Harness from?
Old 05-20-2017, 03:51 AM
Rob 02
Support Corvetteforum!
Rob 02's Avatar
Are there any codes?
Old 05-29-2017, 11:48 PM
FX VETTE
FX VETTE's Avatar
You posted this same question over a week ago and I asked you where you got the harness and lights from - you never answered any of us that responded to your thread.
I asked because I've learned the hard way that not all LEDs are created equal. If you buy cheap LEDs from an unknown auction site vendor you are much more likely to have issues than with a premier vendor.
So, if you actually follow up on this thread - I would suggest that you purchase some LEDs or LED switchbacks that come with the harness that plugs into your old burnt harness after you disconnect the battery and spray some QD Electronic Spray into the old harness. Then plug in and reconnect your battery.
Old 05-30-2017, 12:04 AM
LS1 Goat 91
LS1 Goat 91's Avatar
I have the same issue... mine dim when I apply the brakes or power the lights on. Purchased my LEDs from RadioFlyer. I'll try flipping the bulbs I guess.
Old 05-30-2017, 12:11 AM
FX VETTE
FX VETTE's Avatar
Flipping the bulbs won't fix the issue, they only work one way. I would disconnect the battery and clean the area where the bulb or harness plugs into the old harness really good With QD Electronic Spray cleaner and reconnect everything or resort back to the old bulbs.
Old 05-30-2017, 12:49 AM
Rob 02
Rob 02's Avatar
Did your sockets melt? I had to replace mine.
Old 05-30-2017, 12:58 AM
FX VETTE
FX VETTE's Avatar
Mine were crispy on the top of the plug, but still functional inside.
Old 05-30-2017, 01:55 AM
Rob 02
Rob 02's Avatar
If there is an excessive drain on the battery then that suggest a near short to ground or a very week battery. It makes me wonder if there is some corrosion or something conductive stuck in the socket. Maybe the leads on the base of the bulb got crossed.
Old 05-30-2017, 06:42 AM
BRAVO1
VETERAN
BRAVO1's Avatar
Be careful I had to replace my sockets because of age and one of the sockets was wired wrong and gave me the FITS for a few days until I took a multimeter and verified the leads watch where you get the socket and harness from......
Old 05-30-2017, 12:32 PM
BRKLYN
BRKLYN's Avatar
Good info here, looking to replace lenses and bulbs w LED
Old 05-30-2017, 06:20 PM
Rob 02
Rob 02's Avatar
I'm a huge fan of a certain switchback LED.
Amazon Amazon
It stays a nice bright white until you turn on the flasher then flashes amber only. The day time light is amber and when you turn on the headlights or driving lights they are white.
Old 05-30-2017, 09:54 PM
ZZ06
ZZ06's Avatar
Are your sockets AC delco's? I ask because I ran into an issue with a non OEM socket that worked fine for bulbs but did not for the LED's......
Old 06-01-2017, 11:06 AM
sirdano
sirdano's Avatar
I bought these
Amazon Amazon
and this
Amazon Amazon
I would put stock bulbs back in and see if you still have a problem
To LED problem, 2003 C5 Coupe (Merged)
Quick Reply: LED problem, 2003 C5 Coupe (Merged)
