First gear problems.
2002 Z06
spec clutch
aluminum flywheel
tick master.
Last few days my car had been jumping and some time grinding shifting from neutral to first from a stop about 20 percent of the time.
I bleed the master and adjusted the pedal some more and it seemed to get worse.
Any input?
spec clutch
aluminum flywheel
tick master.
Any input?
uggg i hate t56's
i figured it might be a hydraulic problem.
i may try a swap to syncromesh fluid
i replaced the main shaft and 5th gear and syncro last year and everything else looked in good shape.
That's my next step.
I have it on jack stands now and the wheels are not spinning with clutch in and first gear.
If i go to second first its fine!
