Z06 02 c5 z06? - CorvetteForum - Chevrolet Corvette Forum Discussion
[Z06] 02 c5 z06?
Old 06-18-2017, 08:34 PM
virginc5
Junior Member
Default 02 c5 z06?
how can i tell if it has a z06 package
virginc5 is offline
Old 06-18-2017, 09:03 PM
ArmchairArchitect
CF Senior Member
ArmchairArchitect's Avatar
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Write down the VIN # and enter it into carfax.com or autocheck.com.
ArmchairArchitect is offline
Old 06-18-2017, 09:32 PM
grantv
CF Senior Member
grantv's Avatar
If it's an 02 and an FRC, it's a Z. Why the doubt?
grantv is offline
Old 06-19-2017, 08:41 AM
MY03C5Z
CF Senior Member
MY03C5Z's Avatar
Exactly, pretty tough to fake an 02 model year frc car. Only thing that worried me about mine when I bought it was if it was an ls6, I was concerned it could have been replaced at some point by a base ls1. Easy to see the 243 head stampings, that's one way to confirm it has an ls6. That's still no guarantee but it's a pretty safe bet imo.
MY03C5Z is offline
Old 06-19-2017, 08:55 AM
grantv
CF Senior Member
grantv's Avatar
Yep... a while back a member found out his Z had a base motor. Wonder what ever happened with that.
grantv is offline
Old 06-19-2017, 09:47 AM
glbeauchamp
CF Senior Member
glbeauchamp's Avatar
Where exactly would one look to see this 243 stamp on the heads?
glbeauchamp is offline
Old 06-19-2017, 10:01 AM
MY03C5Z
CF Senior Member
MY03C5Z's Avatar
I believe this is on the driver side, you can clearly see it even with the valve cover on.
MY03C5Z is offline
The Following User Says Thank You to MY03C5Z For This Useful Post:
glbeauchamp (06-19-2017)
Old 06-19-2017, 10:53 AM
MY03C5Z
CF Senior Member
MY03C5Z's Avatar
Yeah that was my only worry when I bought mine, that would really suck to find out later. I checked for the 243 heads when I bought mine from a used car dealer, I figured that was a pretty good sign it was correct. Even then it could be an ls1 block with 243 heads. Probably a way to tell if it's an ls6 block too, I dynod mine and that pretty much confirmed for me it was correct. (363whp)
MY03C5Z is offline
Old 06-19-2017, 12:47 PM
mykream
CF Senior Member
The passenger side head, up front will be the most visible for the stamping.
mykream is offline
Old 06-19-2017, 12:50 PM
grantv
CF Senior Member
grantv's Avatar
Yep. It's stamped on the heads bottom right corner. That places it easy to see on the PS side, kinda behind/under the brake booster DS.
grantv is offline
Old 06-19-2017, 08:29 PM
C5SCCA
CF Senior Member
C5SCCA's Avatar
I've seen two C6Zs in the Tulsa area with wet sump ls2/3 motors...Neither advertisement stated that. You can't be too careful!
C5SCCA is offline
The Following User Says Thank You to C5SCCA For This Useful Post:
ArmchairArchitect (06-19-2017)
Old 06-19-2017, 08:43 PM
MY03C5Z
CF Senior Member
MY03C5Z's Avatar
I knew that was going to start happening with the c6z's. With all the head problems and engine failures out there combined with the cost of an LS7 crate engine, people were bound to start replacing them with LS2/3's. Talk about being screwed over buying one of those! That would seriously suck...
MY03C5Z is offline
Old 06-20-2017, 12:22 AM
grantv
CF Senior Member
grantv's Avatar
...and pretty much no legal recourse. After all, it is still a Z06. That'd be a tough fight.
grantv is offline
Old 06-20-2017, 11:16 AM
MY03C5Z
CF Senior Member
MY03C5Z's Avatar
I would definitely do my homework before buying one these days that's for sure...
MY03C5Z is offline
Quick Reply: [Z06] 02 c5 z06?
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
