How much $ for labor on a Ls2 swap??
what do you guys think would be a fair price for an ls2 swap? Also installing a new clutch, new slave and tick master cylinder and remote clutch fluid bleeder. Engine is fully assembled
I had a mechanic quote me 2K but ive heard people pay between $1200-$1500.
Fellow memebers that have gone through a swap please chime in!
i took out my ls6 to have it built to a fully forged motor as well as install it myself took about 3 or 4 day's working off and on a couple hours at a time..really was pretty easy
Received 3,043 Likes
St. Jude Donor '05
x2 on 2k+-
must be location dependent?
Just to have someone swap a motor in/out of an 02 truck which is super easy averaged $1500. I was floored
Not only are the prices high, the really good shops are too busy to take on time consuming work. I will travel to have work done.
That's also why you can't get a accurate price from the forum. A shop with Corvette specific experience that is all set up may take half the time as a general purpose shop. They may only charge half as much per hour in a rural area compared to one in the city.
Let me check my records that came with the car. My uncle kept everything and he swapped the LS1 with an LS6 in 2003 then he installed an LS2 in 2009. The work was done in Dallas and I can get you the numbers but it was a while ago so I'm sure things are a bit different now.
Engladgreen in Houston quoted me 3K!!! So needless to say I feel like 2k is very reasonable..
