JWM Black Projector HID Headlight System- In stock ready to ship!
#41
I just installed my set this weekend and these lights make a HUGE difference.
Below is a drive by video of my first test drive with the lights. I think I just need to aim them down a bit but I am very happy with the results.
The following 2 users liked this post by Glendows:
Crosis (10-01-2017),
JW Motorsports (10-02-2017)
#43
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
https://youtu.be/VY7gC5BN8c4
Thanks again for the business
Crosis (10-05-2017)
#47
JW Motorsports (10-05-2017)
#52
I see them listed online for 435 or 389 in two different spots on the page? Are these listings both the same? This is without adding any options to either also.
#54
When ordering the HID high beam upgrade option, your setup will use the halogen reflectors on the inside portion, correct? If staying with the stock high beam halogens instead, how effective will turning the high beams on be? Won't the high halogens have a warmer color temp? I'm assuming both the low HIDs and high halogens will stay on when the highs are activated? Are both high and low adjustable in your design?
JW Motorsports (10-23-2017)
#55
Banned Scam/Spammer
The lows will be so bright with our 55 watt HID kit the oem highs won't do much. With this full kit the lows will stay on when you switch to high beams. If you use high beams regularly I suggest adding the HID high beam kit.
The highs are not adjustable. Lows you can fine tune
