Best <$50 LED Low Beam (9006) Head Light Bulbs on Amazon or Ebay?
#62
Probably just claimed 400 watt equivalent (which I also have my doubts about).
My car can put 220 watts of light down the road, and I guarantee that it will be brighter than any of these dinky LEDs.
MikeyMcFly (11-13-2020)
#63
They're probably just vastly overrating them for sales. The ones I got were 40watt each, and used almost the exact same cooling solution. Could the electrical system even output that kind of wattage without modification? I think somewhere I read the stock bulbs are 55watt.
#66
I bought these:
CougarMotor LED Headlight Bulbs All-in-One Conversion Kit - 9006 -7,200Lm 60W 6000K Cool White CREE - 3 Year Warranty
They didn't have the mostplus bulbs on amazon.ca, but I am sure many of these are similar in construction ( as they all come from the same place), I was looking for the Cree name and lumens/watts and shape/size/build construction to be similar as used in this post by nsogiba.
I will be installing this weekend, I will be back with updates.
mre1974 (12-22-2017)
#68
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I purchased the MOSTPLUS LEDs for my 98.
Easy install.. and the light is brighter and whiter.. but the beam pattern is messed up.
I've got the HIR bulbs on order ($35). The LEDs just don't cut it in the stock housings.
#69
Not looking to spend more than $40 because I know others have had success with more generic variants.
If anyone has recommendations, it would be greatly appreciated! Also what features to specifically look for in choosing bulbs for our cars.
For example:
https://www.youtube.com/watch?v=4osgxsQJ_sE&t=206s
Please spare the recommendations for forum vendors.
For example:
Have them in my current C5 and it's obvious the lamps went from yellow to white.
#71
Can you elaborate? It's my understanding that they are filament-based just like the halogens, and therefore project the same as halogens... except brighter.
#72
Sorry - yes.. HIRs on order. Thanks for the reply.
#76
You can only get so much light out of an LED chip. After you hit a certain current through the LED chip, the light output plateaus and all you do is make the LED run hotter (and shorten its lifespan). In actual fact, the hotter the LED is, the less light output it has.
Therefore, the amount of light output LEDs have is determined primarily by the type of LED chip used and the number of LEDs used, not how much power is being put through the LEDs.
#77
Even the MOSTPLUS LEDs are bright enough... Brighter than regular halogens.. it's just that the light isn't projected correctly by the stock housings.
I'm sure LEDs will be widely deployed in headlight applications.. but not in retrofit situations.
#78
A lot of new cars have LED headlights. However, most of them utilize an array of LEDs, rather than a traditional reflector or projector setup. From what I have read, it is hard to get proper light dispersion from just one LED. Even the LED projectors don't have that wide a beam as compared to HID projectors, though they do have a good hotspot.
#79
#80
Received 3,111 Likes
St. Jude Donor '21-'22
So I just did an LED conversion, and I'm pretty happy with it. I used Simdevanma 9006 for the low beam, and Simdevanma 9005 for the high beam. They're 40 watts per bulb(80 per set) and 6000K per bulb. They're plug and play, and fit great inside the stock housing. They do have integrated cooling fans, but I've certainly never been able to hear them running. I use twilight sentinel and my headlights almost always close on their own (although not 100% of the time). When they don't, all I have to do is flip the switch on and off and they close. I have noticed a HUGE difference! The light is brighter, whiter, and has a much farther throw. The pattern is pretty good(I have never had anyone flash their lights at me.) I'll admit they aren't HID, but they beat the hell out of the stock bulbs. Also, I had a half off coupon code, so I got them for $25.00 a set off of Amazon. I figured I would chime in since nobody seems to have mentioned the Simdevanma bulbs. Sorry I don't have any pics ATM.
