Service ABS/Service Traction light
Every time I drive my corvette, the second I reach 83/84 miles per hour the service abs/traction light comes on immediately. When I shut the car off, it goes away and does not come back on. If I reach that speed, it comes on again every time. Wondering if anyone else has had this problem?
If this makes a difference, I have a 1999 Corvette FRC 6 speed manual.
thanks
thanks
I have a similar issue. Sometimes when I start my 2003 I get a DIC message reading Service Active Handling Soon. I've found that restarting the car makes it go away and not come back. It also seems that if I let the gauges sweep and return before starting it is much less likely to occur. This only happens once a week or so (my vette is my DD and usually gets out on the weekend too)
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Do you have stock size rims and tires?
I have stock c6 wheels, I don't remember the tire size off the top of my head but I believe i bought the same size as factory... ill check tonight. In addition, I installed the 01-04 tire pressure monitor system. On my way home from work ill make the light come on and read the codes.
C1226 RF Excessive Wheel Speed Variation EBCM Antilock Brake System
Look at the connectors and see if the pins in them are or are not Deformed
Just adding to what Smoken1 said: Mine had an issue with one of the WSS extension harnesses that go from chassis to the WSS. The extensions are same Rt & Lt so I swapped them side to side & the code followed the bad extension.
