Anyone have a scissor lift?
Does anyone here have a scissor lift? Can you drive right over it? I dont want to put planks of wood down to drive over it.
Any details would help. I'm choosing between a scissor lift or a QuickJack.
BendPak MD-6XP 6,000 Lbs. Capacity (4 3/4" lowered clearance) $2300cdn
Atlas TD6MR 6,000 Lbs. Capacity (5" lowered clearance) $2600cdn
Ranger BL-5000 5000 Lbs Capacity $1800cdn
Roadglide20111 (07-28-2017)
I have a Atlas 7000 drive over lift. The max platform height is 39 inches.
My brothers and friends have and I have pulled 3 drive lines out of C5's on this lift and numerous exhaust swaps. It was the best money on tools I have spent.
I did have to make a set of ramp extensions to get lowered cars onto the lift. They also make it easier to get the pucks under a non lowered car.
Gary
Gary
Roddy13 (07-28-2017)
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
My C5 is lowered on stock bolts, no way would it every be able to drive over anything above 2.5" without damage. My C5 can't be lowered more than an inch so even if you are at stock height you not gonna clear 5" without boards
This my scissor lift 500 bucks. Mine is lowered also. Best 500 bucks spent. Oil changes less expensive . MAGA
I have the Bendpak model you listed. It works great but I have ramps built to drive over it. My Z is stock height and it won't make it over the lift without the ramps.
Gary
Gary
Thought I would add a couple of pics of my lift in action.
Pulled the drive line to change the rear main on my brothers 2001.
Pulled the drive line to change the rear main on my brothers 2001. This is a view from the back after the drive line was puled out.
2011 at stock ride height. There is about .5 to .75 inches of clearance between lift and frame.
Center section is open between the platforms.
Gary
Gary
The following 3 users liked this post by SilverC54me:
Wood of any sort or another makeshift elevation device is nowhere near the safe practice nor convenience of a properly designed lift, especially if any big effort is require for the service/repair. Both my Vettes are low and making a simple step for drive-on/off is no big deal and I have the security of a solid platform to get under.
The KwikLift i bought from a forum member is not ideal but is a compromise ala other options, but beats then snot outta jackstands in all areas.
