Project Mission: STAY COOL BABY! - Page 3 - CorvetteForum - Chevrolet Corvette Forum Discussion
C5 General
General C5 Corvette Discussion not covered in Tech
Old 08-14-2017, 01:52 PM   #41
mstromquist
CF Senior Member
C5 of Month Winner 2015
mstromquist's Avatar
Great job and it looks like you did the job right. Quality control is a big thing in my book. Thanks for the write up.
mstromquist is offline   Reply With Quote
Old 08-14-2017, 01:59 PM   #42
twokbolt
CF Senior Member
Great thread and awesome pics. This will help a lot of people out. One question, did you happen to notice if the Dewitts fans weighed about the same or less as the stock setup?
twokbolt is offline   Reply With Quote
Old 08-14-2017, 02:17 PM   #43
dbgoodwin
CF Senior Member
dbgoodwin's Avatar
Good deal! Nothing quite like a successful mission to start off your car ownership.
Let us know if you get a chance to beat on it a bit, I want to know how she handles the higher RPM load in the summer heat!
dbgoodwin is online now   Reply With Quote
Old 08-14-2017, 02:24 PM   #44
jrprich
CF Senior Member
jrprich's Avatar
Very complete with all the pics!
I would suggest some screening on the underside above the air dam where the air enters.
This will help prevent the build up of trash on the condenser and radiator and will be much easier to check and clean.
jrprich is online now   Reply With Quote
Old 08-14-2017, 03:48 PM   #45
IrishViking505
CF Senior Member
C5 of Month Finalist 2017
IrishViking505's Avatar
...did I mention I put new windshield wipers on too?
IrishViking505 is offline   Reply With Quote
Old 08-16-2017, 10:49 PM   #46
IrishViking505
CF Senior Member
did you do that on yours? Work well?
Specific part or did you fab it?
Old 08-16-2017, 11:37 PM   #47
jrprich
CF Senior Member
jrprich's Avatar
On my 99 and 03 I just used regular fiberglass window screening.
Made a single loop cut to the width of the radiator and ran it from the top of the radiator on the engine side down and under the AC condenser and back up over the top of the AC condenser back to where I started. Joined the two ends with a few zip ties. At least once a year, more often if I see junk build up, I cut the zips and pull out the screen from the top and replace with new. You can make the swap easier by attaching your replacement screen to the old one so that as you pull the old out you pull the new into place.
Keeps all the big crap out and really reduces how much might get through to clog the AC condenser and radiator cores.
I also have one of these which I cover with the fiberglass window screening on the side facing the road. I replace that as well whenever it looks like it needs it.
The Following User Says Thank You to jrprich For This Useful Post:
IrishViking505 (08-18-2017)
Old 08-18-2017, 04:19 PM   #48
IrishViking505
CF Senior Member
Huh, interesting...I may have to consider fabricating something along this line.
Old 08-18-2017, 04:27 PM   #49
IrishViking505
CF Senior Member
Quote:
The new fans from Dewitt's seemed to weigh just slightly less, but it might be marginal. I don't have a scale, so I do not know for sure.
...if they do, it might only be ounces. As far as the radiators go, the Dewitt's is a bit heavier because it's bigger. I think everything balances out though, especially after removing all the crap that was stuck in there!
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Project Mission: STAY COOL BABY!
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    I to ask but am I bleeding cooling system properly? mwm1993 C4 Tech/Performance 12 10-09-2016 09:48 AM
    D3PE PROSPEED - C7Z Cooling Solutions! D3PE C7 Z06 Discussion 10 08-03-2016 03:38 PM
    1960 pushing out water after drive ??? brownacc C1 & C2 Corvettes 16 10-12-2015 09:14 AM
    radiator surge overflow tank Ja's_baby C5 General 4 05-07-2011 09:43 PM
    Up date on coolent flush JEEP/C5 C5 Tech 4 02-03-2009 12:07 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    Question Title:
    Description:
