Weather Strip Lubercant
Received 1,211 Likes
Need some opinions from forum's tech guys. Currently, I put on a thin layer of Dielectric Grease on all my weather striping each spring. GM recommends using their brand of fluid #3634770 (Amazon $58.73) for weatherstripping. Not sure of the chemical make up of the GM fluid. Your thoughts are appreciated on what you use and is their a GM fluid like substitute. Thank you.
rrwirsi (08-13-2017)
Received 1,679 Likes
My choice
rrwirsi (08-14-2017)
Received 19,223 Likes
'20-'21-'22-'23-'24
I use a natural silicone lubricant on mine - keeps the weatherstripping looking and feeling like new. Got the stuff from a local body shop years ago.
Comes in 4 and 8 oz. tubes...the difference in dielectric grease and sil- glyde is that dielectric grease has a compound that is more for conductivity and Sil-glyde is for protection of rubber products...you do not need dielectric grease...
I have used this great stuff for years...its not expensive at NAPA...
1/4 mile/AutoX
Chadwick's no sling tire shine !!!!! made all my hoses and weatherstrips like new !!!!!
The following 2 users liked this post by Pounder:
doublenut9 (08-14-2017),
Gary Collins (08-14-2017)
I use "AC Delco Dielectric Silicone Grease" which is the GM recommended lubricant. It is really expensive if purchased through the dealership, however, I purchased it on Amazon for $18.59. While it's still expensive compared with other alternatives listed in this thread, I was fine with it.
Received 1,227 Likes
St. Jude Donor '11
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
How about Dupont Teflon Silicone Lubricant: https://www.walmart.com/ip/DuPont-Te...089#about-item
It says "Waterproofs, protects, lubricates and preserves. For use on rubber, plastic, vinyl, leather, metal and wood."
Or Meguiar's M5716 Marine/RV Vinyl & Rubber Cleaner & Protectant which also has UV protection but is not silicon-based:
Started using Honda branded silicone lube after reading owners' zeal from S2000 owners. Rare and expensive.
Now, alternate between it and Maguire's Protectorant for the UV protection. Some swear the silicon will not be absorbed into the rubber.
Received 2,705 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
The following 2 users liked this post by knewblewkorvette:
The Rabbi (08-14-2017),
vetintheblood (08-15-2017)
Does it work good on the weatherstripping blew?
I use to condition and protect all the weatherstrip in my C5 and I really like it. No greasy residue like when you use dielectric grease.
I tried (this week) Do It Best Hardware "Do it Plumbers Faucet And Valve Grease" - 050035. It is silicone based, and specifically talks about keeping O rings pliable, as well as waterproof. It is far less cost than the GM stuff (that did not work at all for me) at $3 or less for a 1 oz. tube.
I estimate that the tube would do 2 treatments of all door and hatch weather stripping on a coupe. And (in a tube) far easier to use than the 33 Aerospace spray.
So- the jury is still out. But after a couple days it seems quieter.
I'm neither a designer, engineer, chemist, nor manufacturer of automobiles. I just drive them, by necessity and for pleasure.
Consequently, I rely on the product these people recommend I use to for the best care of my very expensive vehicle.
I would not use an alternate weight engine oil, oil filter, gasoline octane, or inflate the tires to other than the recommended air weight, so I see no reason to deviate from any other recommended product. Yes, I'm fully aware of a built-in product bias.
