Corvette taillights on Travel Trailer
#83
Nope, Amazon 2 of GENSSI 3157 3057 3156 Socket Wires Connector Base Adapter (Pack of 2)
Could have easily been my error. The male plugs looked right but would not seat in the female OEM sockets no matter how hard I tried
So I just used wire taps and taped over the female sockets. Works just fine.
#84
#85
PartsSquare New! QTY(8) 3156 3157 Male Connectors Harness Fit Tail Lights DRL
The following 4 users liked this post by Stephen Meredith:
ArmchairArchitect (02-18-2018),
BlackHellcat (02-16-2019),
J. Kent (07-18-2018),
Raiden8816 (02-15-2018)
#87
Sorry, I do not have pics
#88
So I completed the wiring on the project. I’m honestly not happy with the tail light fitment compared to stock. I’ll see about taking the stock lights apart and swap the LED guts into the OEM housings.
#89
#90
#91
Ordered the set of 6 RV lights from ebay and the wiring harnesses from Amazon. Will be installing RadioFlyer ACA headlights this weekend but then it's the tail lights. I'll also need a hyper flash harness, right? Are they all the same? Prices range from about $40 on ebay to $65 + S/H at RadioFlyer.
#93
I ordered these lights right after reading the original post. i also ordered the hyper flash relay as well. They've been on my 99 now about 6 months. What a great upgrade! Simple wiring, did not need any harness. I simply cut off the factory sockets and wired them up. Best mod I've done so far.
#94
I ordered a set for 50 bucks and figured i'll toss them on the shelf. what the hell. i'll tint them later and figure it out lol. for 50 bucks they're worth messing with.
ArmchairArchitect (07-13-2018)
#96
Same here. Lights off of ebay, adapters from Amazon. Soldered and used marine shrink tubing. Hyperflash adapter was previously installed. They are tight in the socket which caused some concern. Look and work great.
#97
Stephen Meredith: Thanks for instructions on wiring the Amazon wiring harness to the LED lights. Just a thing to remember: LEDs are polarized but the plug on the wiring harness can be inserted into the stock bulb socket either way. Check each one before connecting everything. If the LEDs don't light up, rotate the plug 180°
And of course thanks to Andy!
Now here's my problem: The RV fixture does not seat all the way into the fascia. It looks to me like the LENS is the same size as original but the black backing is about 7/16" thick and squared off, so the backing is preventing the unit from going all the way in. I think that's what Raiden is talking about.
I don't want to mess with the stock lights--want to keep this all "Plug & Play" and easily reversible. I may try putting a bevel all around the perimeter of the LED units (sounds tedious) or maybe using spacers.
Ordered the hyper flash harness off ebay for $41 and just waiting for it to arrive.
btw--installed the RadioFlyer ACA headlights. MUCH brighter! Now I have to aim them...
#98
[QUOTE=J. Kent;1597622353]
Now here's my problem: The RV fixture does not seat all the way into the fascia. It looks to me like the LENS is the same size as original but the black backing is about 7/16" thick and squared off, so the backing is preventing the unit from going all the way in. I think that's what Raiden is talking about.[QUOTE]
Odd,
Mine fit just fine even with tail light shield gaskets.
Odd,
#100
OK. After some cutting and sanding of the RV light it finally occurred to me: The thickness of the original tail light at the mounting hole is about 1/2". The RV light is about 7/8" thick at the mounting hole, so the lens will always be 3/8" out compared to stock.
Fine. CorvetteMods (for example) will sell you a "Flush Mount Tail Light Kit" for $25 + S/H. So it's not a problem--it's a mod
Got the hyper flash unit so as soon as I attach plugs to 4 RV lights I'll just install them, flush mounted, and quit worrying.
