Corvette taillights on Travel Trailer
#161
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
Hi, are your lites the trailer lites that we've all installed? If so, did you buy 6 instead of 4? If so, just wire one of the extra ones in where the bright one is now. I've wired up 2 sets of these and haven't your problem on any of them. Please post your results.
Dave
Dave
#162
Led t
Dave
#163
Banned Scam/Spammer
Thanks again to the OP for this awesome inexpensive mod. Really updates the look of the C5 and I haven't done anything to modify the LED lights like others have with the halos etc.
#164
Received 3,866 Likes
2015 C5 of the Year Winner
Thanks for updating this thread with your fix for it. I'm sure it will come in handy for some one with the same issue.
#165
Help!
I ordered and received the trailer lights for the rear tail light mod, I also ordered and received, C5 Corvette LED Hyper Flash Harness hyper flash by Corvette Envy and 4 x 3156 3157 4157 Socket Car Bulb Holder Adapter for Turn Signal Light.(All Parts ordered from EBay)
I have everything in stalled and hooked up, all 4 rear light are working and look great, but I have NO right or left rear turn signal. I have front right and left, but NO rears?
Any Ideas what I may have done wrong. Didn't have time to check my work, because I had to head off to work. The wire connections I used is listed below.
Page #80 on Corvette Forum
Cool thank you! Since those adapters are black/red/blue how did you wire them?
Adapter Red > LED BLACK ??
Adapter Black >LED WHITE
Adapter Blue > LED RED ??
Thank You In Advance
[font]C.J[/font]
[font]C.J[/font]
#166
from post #42 (I think). Unfortunately I did not keep a record of the corresponding colors on the harness but you should be able to figure it out from this info
OEM tail lights:
Left lamps have:
Brown connects to the LED BLACK wire
Black(ground) connects to the LED White wire
Yellow connects to the LED RED wire
Right lamps have:
Green connects to the LED RED wire
OEM tail lights:
Left lamps have:
Right lamps have:
#167
I bought these on amazon. Worked great. Wired white on the light to black on the plug. Red to red. And black on the light to blue on the plug.
PartsSquare New! QTY(8) 3156 3157 Male Connectors Harness Fit Tail Lights DRL https://www.amazon.com/dp/B00UJEGY66..._LkscNQRnYTxeV
Also remember: LEDs are polarized but the plug on the wiring harness can be inserted into the stock bulb socket either way. Check each one before connecting everything. If the LEDs don't light up, rotate the plug 180°
#168
All my light are working, just No rear turn signals? I have the same connectors,just used a different wire connection sequence. I will try your wiring sequence and see what happens.
#170
I can't seem to find the 6 but here's a listing for 2 of them.
https://www.ebay.com/itm/2-RED-Stop-...edirect=mobile
#171
#172
Now that I look at those again they have an extra light on the bottom of them for a license plate or something. I'd probably pass on those. I'll keep looking and see if I can find anything.
#173
try this link , looks like the same ones I bought , does not appear to have the license plate light in the bottom . says he has 6 left
https://www.ebay.com/itm/2-RED-Stop-...V/111707605912
#174
Ooooo sub'd for the future!
#175
Banned Scam/Spammer
Anyone have an issue with some of the small LED bulbs within the tail lights burning out? I have a lot of interior LEDs in my car also, along with LED headlights, so wondering if too much voltage is running through these tail lights? Not sure if that's the root cause, or just poor quality of these tail lights?
#176
I had my tail lights installed since the beginning of this post I have also all leds in my car as well. no problem what so ever. maybe you got some bad tail lights?
#177
Like you, I've replaced virtually every incandescent bulb with LEDs and have not had a problem (that is until I installed the Dyna Flash tail light flasher. That thing threw error codes)..
#178
Tried this mod recently and it still works perfectly. Ordered lights off ebay (Note: could only find 2 lights per order, so bought qty 2 for 4 total lights). Got the male connectors off amazon to have plug and play lights. No modification to cars wiring. Nice and bright plus a major upgrade look over stocks all for a total of $70 bucks.
#179
Banned Scam/Spammer
Mine are still going strong 2-3 years later and I still love the look over stock, especially for the low price paid.
The previous issue I mentioned was actually a non-issue, it was the angle from which I was looking at the light made it appear that some of the LED diodes were dimmer.
yanman96 (09-08-2021)
The following 2 users liked this post by Mitch45:
ArmchairArchitect (09-08-2021),
