[Z06] LS6 clutch Carnage.
Old 09-25-2017, 08:40 AM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
Originally Posted by Moto One
Just sent you a long (really long) PM reply. Looks like you are already done. On the adjustable TB be carful not to over adjust the through, it can go to far and cause damage.
Mark.
Thanks for the detailed PM.
Posting this here in case this here to possibly spark others' imaginations.
Planning to put the smaller C5 pilot bearing in, and before I install the clutch, I'll put just the torque tube in (without transmission attached) and bolt it down to the bell housing. That way I can look in from the bottom and visually inspect the input shaft to pilot bearing engagement. Once verified I can then install the clutch and everything else knowing 100% I'm good to go.
Moto One (09-27-2017)
Quick Reply: [Z06] LS6 clutch Carnage.
