Z06 C5 Z06 battery weight - CorvetteForum - Chevrolet Corvette Forum Discussion
[Z06] C5 Z06 battery weight
Old 10-12-2017, 10:24 AM
HT1663WB
CF Senior Member
HT1663WB's Avatar
Default C5 Z06 battery weight
Does anybody know the weight of the factory battery that came in the Z06? I read that GM used a lightweight battery. Thanks!
HT1663WB is offline
Old 10-14-2017, 03:15 AM
striper
CF Senior Member
striper's Avatar
I doubt at this point in time you are going to find a C5 with its original battery. Basically they were all garbage. I've been running an Optima red top in mine for along time. Don't know the weight though.
striper is offline
The Following User Says Thank You to striper For This Useful Post:
HT1663WB (10-15-2017)
Old 10-15-2017, 07:30 AM
MY03C5Z
CF Senior Member
MY03C5Z's Avatar
Also be aware that there were many cases of the original lead acid batteries leaking, and it's mounted directly above the cars computer. Really bad location for an acid leak. That's another reason to switch to an AGM style battery like the red top, they don't leak. I've had a red top in mine for 6 years now.
MY03C5Z is offline
The Following User Says Thank You to MY03C5Z For This Useful Post:
Old 10-15-2017, 09:10 AM
HT1663WB
CF Senior Member
HT1663WB's Avatar
I was just curious about the weight. I had read GM used a light weight battery in the C5 Z06. I replaced mine a couple years ago with an ACDelco battery from the Chevy Dealer...it's 32lbs.
HT1663WB is offline
Old 10-15-2017, 10:46 AM
Millenium Z06
CF Senior Member
Millenium Z06's Avatar
My factory battery was an AC Delco AGM battery. It wasn't any lighter than any other AGM battery I've replaced it with.
Millenium Z06 is offline
The Following User Says Thank You to Millenium Z06 For This Useful Post:
Related Topics
Thread
Forum
Replies
Last Post
Tonytz06
C6 Corvette ZR1 & Z06
7
12-17-2017 02:58 PM
drkschoi
C7 General Discussion
24
12-09-2017 02:19 AM
Roadcone
0
05-24-2017 05:11 PM
usmcpony
C6 Forced Induction/Nitrous
9
07-10-2016 11:57 AM
PHILLY JOE
C5 Tech
5
05-01-2016 11:21 PM
Forum Jump
Sponsored Ads
Vendor Directory
  • Ask a Question
Question Title:
Description:
