105k and done. My LS 1 ate it.
#41
if you can...go w a forged bottom end and look at fueling, exhaust etc while you are putting it back together....even though pricey...it's a good opportunity to do a few things while it's apart and set yourself up to go fast in the near future.
#42
#43
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
A lot of different options have been pointed out and budget will probably be the biggest factor. Least expensive would be a used engine from VetteNuts (or perhaps something in the Phoenix area). The engine Pewter99 has sounds like a well built, strong option, although if you're not going with some form of forced induction you may want to do head work to bring compression up. I'm thinking that if you go the route of rebuilding with forged internals and have to pay someone to do this build, then it might be just as cost effective to buy a new Chevy LS3/LS376 crate engine - you can get them from 430hp to 535hp (IIRC). Good luck.
By the way, we used to have a place in Arizona Traditions in Surprise. Nice, but way too many restrictions written into the C&R.
#44
If you go with LS3 with hot cam already installed from GM it supposedly makes 495 HP or 450 rear wheel horsepower.
No need to change reluctor wheel, just run the 58 to 24 box.
This is what I would do if I was in your situation.
#45
If you want to swap in a engine in your garage, and you have a engine hoist, I'll help you do it, soon we will have nice weather here.
Could probably knock it out in a couple of weekends, not saying it would be easy, and I've never swapped a engine in a Corvette (but have on a few other cars and rebuilt 2 engines), but I'm willing to help out.
PS, the catch is, you will be required to get pizza and wings.
#46
#49
If you can get the right equipment, the easy way is to drop the whole driveline; rear sub, TT, and front sub as one assembly. I too recommend a LS3 swap. The forged, low compression short block would only be optimal if you plan on adding FI.
#53
Banned Scam/Spammer
Received 1,319 Likes
When it's time for a new build it's going to be lightweight crank, rods, pistons, flywheel, clutch, and valve train.
Redline will be 7500-8k matched with the M12 gearing.
Do what you want, I've had two forced induction LS1s, an LS7, and when this Bling LS6 I have is ready to retire, a high compression, high rpm screamer is set to be put in.
This 9500rpm redline 388ci sounds so good. Imagine hanging onto this cheetah at full tilt.
#54
#55
#56
#57
If you swap out to a 24x reluctor (about the same difficulty as changing the cam, if I recall correctly the reluctor is part of the cam), then you wouldn't need that module. Everything will be literally plug and play, just need to run a couple of sensor extensions and get a tune. The LS series engines (and by extension the GM small block Gen III and IV) share almost everything.
#58
#59
If you can find a L92 out of an Escalade, or even an LS3 from a Camaro, they can go for about $4-5k. I think I've seen L92s as low as $3k, and the only difference between the L92 and LS3 are the heads and cam if I recall correctly. Of course, LS2s and LS1s are cheaper, but from my watch on Craigslist the price difference hasn't been great enough to make them a better value.
Between rebuilding yours and getting one from the junkyard, I think the costs will come out similar. Of course, you could always try going the $10+k LT1 route and be the first to have the LT1 in a C5 Pretty sure the computer adapters aren't there for it yet though.
#60
Banned Scam/Spammer
Let the car sit for a minute.
Buy once, cry once is the saying. -lots of extras involved just putting in a stock engine, much less modded. It's a Corvette, they're meant to be worked on. Just hope it doesn't turn into a barn find.
